04-21-2022, 06:36 PM | #1 |
headers for 50's style hot rod 32 roadster
The engine build for our 32 rod continues. I am interested in any information concerning an appropriate set of headers and also best ideas for the full exhaust. The engine is a 8BA.
04-21-2022, 11:43 PM | #2 |
Re: headers for 50's style hot rod 32 roadster
04-22-2022, 12:09 AM | #3 |
Or Fentons.
04-22-2022, 07:01 AM | #4 |
Thanks both, I'll look into them.
04-22-2022, 07:39 AM | #5 |
I've used Speedways Y type headers on a couple 32's with stock style steering boxes and am using Fenton's on my latest deuce roadster with Vega steering. Also used Sanderson's on a few customer cars.
04-22-2022, 07:56 AM | #6 |
Pictured headers are by Sanderson with by-pass built but not fitted. The choices are many. Flatties don't produce an obnoxious exhaust note but rather a unique sound. I like the exhaust running through unbaffled glass packed mufflers that tone it down a bit without killing the unique sound. Flaunt the flattie I say!
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa. Last edited by john worden; 04-22-2022 at 08:23 AM. Reason: info |
04-22-2022, 08:01 AM | #7 |
Google Fentons in the '32 with stock steering. IIRC, I don't believe they fit.
04-22-2022, 08:13 AM | #8 |
The most common style of headers (within the frame rails and under the car) are the 'Belond Style' of headers - which Red's has. Red's makes a good product, but in my mind you'll want to customize them and make them better. Everybody seems to have copied the Belond headers from the 50's - with no turn-downs, no flanges, etc -- which makes no sense in my mind.
One thing that I always do is modify these style of headers and add 2-bolt flanges to the ends of them - so that I can easily attach/bolt on the pipes that go to the mufflers. Also, I usually add 90 degree "turn downs" onto the ends of the headers - such that I can easily route the exhaust under the frame rails (and to the sides or out the back). So, given that I'm going to modify them, I don't order them coated and I do all the TIG welding and routing of the exhaust system before I even think about coatings. You'll find that if you invest some time into making it easy to take them on/off (same with the complete exhaust system in general), you'll be very glad you did later on! Don't make the mistake of trying to use a 'slip fit' set of extension pipes that slide over the as-delivered headers (with u-bolts to clamp them on) - as if you even manage to clamp the slip-fits tight enough to not leak (which is a problem unto itself), you'll play Hell ever getting them to "slip back off". Ask me how I know these ugly things! LOL> |
04-22-2022, 10:56 AM | #9 |
I used the cheapo Speedway center dump headers. I did not split the wishbone on my
'32 p/up and with a little creativity made them work. I'm using a '48 truck steering box. I really like the look of the center dumps....all business. FYI I placed the battery, '53 Olds long boy ,in the front of the bed so no issues there. Home brew head pipes and Toyota p'up mufflers Charlie ny |
04-22-2022, 11:52 AM | #10 |
You need to consider what steering box you are going to use. The Fentons that I have do not clear the stock "32" box.
04-22-2022, 12:45 PM | #11 |
I bought a set of cheap stainless center dump headers for use on my engine stand. IIRC, they were just over $100. The headers are great, but they came with metric mounting hardware! After replacing all of the bolts they fit fine. (I did have to use socket head bolts in a couple of tight places, but other than that, I like 'em.)
04-22-2022, 01:01 PM | #12 |
For those with tight bolt head clearance issues, they sell reduced size head header bolts. I have to use one on the headers Zac Suhr fabbed up for my roadster. No way would a full sized headed bolt work without dimpling the tube; which I did not what to do.
04-22-2022, 01:04 PM | #13 |
Right. However, the local hardware store had socket heads, but no header bolts. Plus, it's an engine test stand.
04-22-2022, 01:18 PM | #14 |
04-22-2022, 01:21 PM | #15 |
The special header bolts are better. They are flange head, while socket heads are not.
04-22-2022, 01:24 PM | #16 |
