01-10-2021, 11:11 AM | #1 |
52 F1 cluster gear
I have been working on building a 52 F1 3 speed remote shift transmission. Mostly all NOS parts including the case. I have built several before, but this time I am paying more attention to part fitment. I am using a NOS 27-23-17-13 cluster with needle bearings. I noticed the spacer isn’t a precise fit in the cluster bore. It’s not extremely loose, but not a tight fit either. I wonder why the spacer was designed that way? Seems like it’s an opportunity for transmission noise when the cluster rotates?
JB |
01-10-2021, 01:48 PM | #2 |
Re: 52 F1 cluster gear
diameter? probably some inexpensive off the shelf tubing, noise it should be drowned in trans fluid and thus no noise
01-10-2021, 02:15 PM | #3 |
