12-31-2020, 10:42 AM | #21 |
Re: 12v from 3 brush Ford generator
The "button" diodes (3 of them) are pressed into the deeper recesses of the aluminum rectifier heat sink in an alternator. A better choice for cutout mod is a stud mount type with heat sink compound for better heat transfer to the bus bar. Diode should be rated at least 25A. Use 12AWG for connection.
Example for negative ground - https://www.ebay.com/itm/50-AMP-1000...-/121864495540 Positive ground type also available from the same seller. |
12-31-2020, 11:01 AM | #22 | |
For example, it you have a total of 60 watts of power requirement on a 6V system, the generator has to provide 6 volts x 10 amps = 60W. Converting to 12 volts, if the 6V light bulbs are replaced with equivalent power 12V bulbs (and the coil), the total power requirement will still be 60W, and now the generator will need to supply only 5 amps; 12V x 5 amps = 60W. |
12-31-2020, 11:04 AM | #23 | |
12-31-2020, 11:13 AM | #24 |
Thanks to both of you. I am looking at increasing the wattage needed, looking at 20 amp peak @12 Volts. I know an alternator would likely make a better choice, but I want the look of the Generator. This thing won't see much use, not likely to see 5 hours on the engine over a years time.
Plus, anyone can put an alternator on. Due to the load, I ordered a 40 amp diode earlier from the source suggested instead of the one recommended by Sparky Thanks again... Big help. |
12-31-2020, 11:19 AM | #25 |
They won’t tell you if or when they will make one for you.
12-31-2020, 04:48 PM | #26 |
01-01-2021, 11:21 AM | #27 |
It would be hard for them to help a customer if they can't make the product. Expecting a different outcome from folks when they can't come through is problematic. If someone can't help you it doesn't mean that they are unhelpful. They just can't help you.
This is a far cry from being dishonest so don't poo-poo folks unless their is a good reason to do so. |
01-03-2021, 10:27 AM | #28 |
Pdgx I never heard of the fun products and thought it would be more fun then a regulator:}
Thank you sparky for the information and plan to make one and put it into a original ford case like the fun products.
Wanted flathead speed equipment Thanks |
01-03-2021, 10:45 AM | #29 |
My only concern about the Fun Projects Voltage Regulator is that it regulates the output of the generator and not the generator field itself. You adjust the output of the 3rd brush to get 8 to 10 Amps then put on the regulator. Controlling the field strength which is essentially adjusting the 3rd brush is the best way to regulate the voltage out of the generator instead of converting to heat in the Fun projects regulator. The Fun Projects regulator does work very well. I am looking to find or design an electronic regulator that controls the field current. Tom Westberg has one for 6V, but not 12V. Finding electronic parts any more is difficult as there are no stores like the older Radio Shacks where you could find discrete components.
01-04-2021, 10:24 AM | #30 |
@jrelliott - You're right about the FP regulator. It is a shunt regulator, which means it simply dumps excess generator power to ground. I figure it wastes about 1 HP at the high end. 1 horse doesn't sound like much until you consider there are only 40 to start with (or you try to wrestle a horse).
The series regulation used in Tom Wesenberg's design is much more efficient. It simply interrupts field current when set voltage is exceeded, limiting the output. Regulators for a model A aren't that hard to design, considering the requirements are quite simple. A few common parts are all that is required. There are many parts suppliers online. Just google for any part and you'll find lots of sources. |
01-15-2021, 12:52 PM | #31 | |
Jon. |
01-16-2021, 10:15 AM | #32 |
Depends on forward voltage drop (Vf) of the particular diode. If you can't find the spec sheet, figure 1 volt drop: 1V x 20A = 20W. Grab onto a lit 20W bulb to find out how much heat sink is required. The copper bus inside an original cutout should suffice. Just be sure the arrow on the diode points toward the negative side.
01-16-2021, 01:56 PM | #33 |
Thank you....
