10-01-2020, 04:10 PM | #1 |
roof/door trim rail.....perplexed
I am working on a 1930 fordor sedan.....Briggs. There is a rail/trim piece which is is mounted above the doors and runs the length of the car from windshield to behind the rearmost side window immediately above the doors. It curves down on the tail end. It is nailed into the wood frame and serves as a molding between the tops of the door frame openings and the roof panels above. It also, judging by its shape, serves as a drip rail (gutter) to shed water off the doors/windows.
So.... I can find no mention of the piece in any reference material i can access in manuals, catalogs or on line. Would like to know it "official name" so i can at least refer to it properly. The nails which attach it to the wood frame are built into this rail (it appears to be a two piece deal pressed together). It is about 75 inches long. It has what looks to be a heavy paper or cardboard "backing" perhaps for squeak supression??. I have talked with the parts guru at Brattons and he said he is not familiar with this piece or its "gasket". I feel like maybe i am not using the right terms to explain. Feedback appreciated. |
10-02-2020, 04:20 AM | #2 | |
Re: roof/door trim rail.....perplexed
Can you post some pictures? Sent from my iPhone using Tapatalk |
10-02-2020, 09:35 AM | #3 |
sounds like he is talking drip rails
10-02-2020, 12:34 PM | #4 |
Yep Drip rails. Gasket, that I would like to see as well.
Mike
10-02-2020, 01:50 PM | #5 |
I agree with "drip rails". However, i didn't find any such animal or its gasket at brattons, snyders or macs. I just felt it was odd that there is no mention of them. Trying to post pics but doesn't seem to be allowing me to do so here. guess i will resurrect the old ones and get some thin gasket paper and make my own gaskets.
10-02-2020, 01:54 PM | #6 |
10-02-2020, 04:32 PM | #7 |
Looks like A-168274-BR Moulding (roof side drip) R. H. 155-D, 165-D
A-168275-BR Moulding (roof side drip) L.H. 155-D, 165-D |
10-02-2020, 05:50 PM | #8 |
what is the secret to uploading pics......can't seem to make it happen.???
10-03-2020, 09:26 AM | #9 |
The Briggs and Murray sedan bodies only have a metal skin over the wood structural element. The drip rails are not reproduced and it's even getting harder to source the moldings that go around the top fabric. If they are missing then a person either has to find some good ones that are at least repairable out there or they would have to try to reproduce a facsimile of the originals. The skin under them has holes for the nails to install them and the wood is directly under the metal skin. This is just the way that the lower production bodies were made by Briggs and Murray.
The bodies made by Briggs and Murray are difficult to restore so a lot of folks shy away from them unless they have been well kept and all their rare pieces are still there and in good condition. Restoration of the Fordor and Cabriolet cars are amongst the most difficult with exception to the Station Wagon types and it's mostly due to the extensive use of wood. Last edited by rotorwrench; 10-03-2020 at 09:35 AM. |
10-03-2020, 09:41 AM | #10 | |
I use Tapatalk on an iPhone, and picture upload is fairly straightforward. If you are using a web browser, picture upload is more complicated. There is an “Insert Image” button just above the scroll box where you type your message. If you click on that, it prompts for a web location (today). I haven’t used a web browser in a while to upload pictures to the Ford Barn. There should be a “Manage Images” button (or something like that) somewhere on that page, but I can’t find it today. The inability to post pictures is a frequent complaint. It’s not overly intuitive. Maybe someone else can chime in. Sent from my iPhone using Tapatalk |
10-03-2020, 02:11 PM | #11 |
i keep getting a message saying i do not have the "security token" wtf that is.
