04-10-2021, 09:56 AM | #1 |
1940 ford rear suspension add ons
My truck came with added on shocks and coil springs in addition to the single leaf set up.the stock shocks are gone.i can reuse the aftermarket shock mounts with some dressing up but are the coil springs necessary?
04-10-2021, 11:11 AM | #2 |
Re: 1940 ford rear suspension add ons
Heavens NO! That sounds like someone with dung for smarts got completely carried-away with one of the dumbest "SOLUTIONS" to a problem requiring a much more reasonable, and acceptable approach to what was likely, a sagging rear spring. DD
04-10-2021, 01:39 PM | #3 |
Thanks v8coopman,it just didn't look right.the coil springs are bolted on so they will come off easy. I may re mount the shocks but their ok for now
04-10-2021, 01:43 PM | #4 |
The single leaf needs some friend = more leafs . Depending on model 9-12
04-10-2021, 02:31 PM | #5 |
Toss the single leaf and put a stock spring in the back. Get rid of those coils that are around the shocks.
04-10-2021, 04:04 PM | #6 |
04-10-2021, 04:10 PM | #7 |
Just need to see what you have with the coils removed. If it is low in the rear it may need the spring replaced or re-arched.
04-10-2021, 04:46 PM | #8 |
I'm not sure why the beefed up suspension. The bed isn't big enough to haul much. well see when I get the coils off how she sits
04-10-2021, 06:55 PM | #9 |
I misunderstood your description of single leaf . If your currently have the factory spring and its in good shape just use the tube shocks . What was the addition of coil overs used for ? More height , carrying a load , compensate for worn spring ? I know its only a guess as to what the previous owners intention was unless its obvious. What got me was the single leaf as they are made aftermarket with just one leaf . Ive even seen all the leaves removed except the one connected th the shackles and over load coil springs bolted to the axle under the frame rails .
04-10-2021, 07:01 PM | #10 |
Ggmac, I was confused also by the single leaf. Thought maybe it was one of those Mono Leaf springs.
04-11-2021, 06:30 AM | #11 |
Thanks for all your help and input.Im thinking I'm going to remove the original spring,clean and reassemble the original spring.i think it has a lube fitting to lube the springs.Ill trash the coolest, clean up the tube shock mount and get some good quality shocks.ill let you know how it sits
04-11-2021, 09:14 AM | #12 | |
Your plan sounds good , leaf springs take a special grease. |
04-11-2021, 09:22 AM | #13 |
you can use fifth wheel slip plate grease on the springs
