04-08-2021, 08:26 PM | #1 |
32 3W female door guides
Anyone have experience reassembling 32 3w female door guides? I can get the wedges and springs into the housing but I can't get them into correct working position. I'm about ready to drill a hole in the backside so I can push them around. Any advise?
04-09-2021, 08:29 AM | #2 |
Re: 32 3W female door guides
As I recall they should snap into place. Push them back as far as they will go and push downward at the same time.
04-10-2021, 01:55 PM | #3 |
TJ, Thanks for the reply. Everything you stated is true. Only problem, the spring loaded wedges are not co-operating. Heavy intervention with a screwdriver gets one wedge in place, the other remains cocked. Push the cocked one into position and the other gets cocked. Back and forth, do this for an hour = *^^$@@$%^ Think I'll drill a hole in the back to see if I have better luck pushing them into place from there. Thanks again.
04-10-2021, 02:28 PM | #4 |
