02-28-2015, 03:25 PM | #1 |
Overbore effect on compression ratio ?
At what point can we get into the danger zone with a 5.5 or 6.0 head??. I have good babbitt. How much will it move at .030 .060 ect. through .125 ?
02-28-2015, 03:48 PM | #2 |
Re: Overbore effect on compression ratio ?
Bore changes don't change compression ratios as much as stroke changes----you will hit water before you get compression high enough to hurt good babbitt ----
02-28-2015, 04:33 PM | #3 |
You just have to do the math. If the diameter is increased by 3%, then you square that and compare it to the old compression ratio. So, lets say the old ratio was stock 4.22 to 1, then you multiply 1.03 x 1.03 = 1.0609 x the old compression ratio. 4.22 x 1.0609 = 4.477.
02-28-2015, 08:38 PM | #4 |
babbitt is good up to and including CR 7.0
'31 180A |
02-28-2015, 11:41 PM | #5 |
That's a conservative number.
Ed Winfield who I'm sure everyone into model A's has heard of, ran 11 to 1 in his race engines in the 30's. He ran babbitt and the engines easily went 100 miles in dirt races which are a lot harder on an engine than pavement racing. He turned the engines 5000 rpm twice every lap. He was almost unbeatable. Pretty good testimony to babbitt. |
03-01-2015, 01:11 AM | #6 |
J |
03-01-2015, 10:54 AM | #7 |
The compression ratio is the ratio of the volume of the combustion chamber (a) plus the volume of the cylinder (b) divided by the volume of the combustion chamber (a).
Or, (a + b)/a. This reduces to 1 + b/a. The new combustion ratio would be (a + (1.0609)b)/a. Or, 1 + (1.0609)b/a. If the original combustion ratio is 4.22, then 1 + b/a = 4.22, so b/a = 3.22. The new combustion ratio would be 1 + (1.0609)(3.22) = 1 + 3.416 = 4.416. Slow: one finger typing on an iPad. |
03-01-2015, 12:03 PM | #8 |
167.5 John! Babbitt mains but switched to insert rods because of a piston change. Ran babbitt rods with 12:1 compression for years.
03-01-2015, 12:34 PM | #9 |
03-01-2015, 12:59 PM | #10 |
Jim, very impressive indeed!!!
'31 180A |
03-01-2015, 01:15 PM | #11 |
The spec's on the Rajo, and Gulavan "SP"?, duel over head cam engines, with the Hemi shaped combustion chamber was 14 to 1 on babbitt.
Herm. |
03-01-2015, 01:39 PM | #12 |
03-01-2015, 02:15 PM | #13 | |
Well don't forget to subtract the volume occupied by the piston above the deck. Plus add the volume of the gasket. |
03-01-2015, 03:56 PM | #14 |
03-01-2015, 10:53 PM | #15 |
My 31 sport coupe is .125 overbore and has a B, police head Although it ran hot at first, It's ok now and is my best running Model A.
