Old 11-06-2018, 10:17 AM   #21
fsacht
Default Re: Brighter 6v bulbs for early fords
fortyonerag, yes, they do work with positive earth (ground).
fsacht is offline   Reply With Quote
Old 11-06-2018, 01:55 PM   #22
uncle buck
uncle buck's Avatar
Originally Posted by fortyonerag View Post
Do they work with positive earth?
Be careful , The 6 volt LED's I bought would only work with negative ground. The seller claimed they work either way and they didn't
uncle buck is offline   Reply With Quote
Old 11-06-2018, 04:07 PM   #23
Kurt in NJ
Kurt in NJ's Avatar
My friend bought a Packard, it came with several "bright" bulbs for the tail/ brake lights,halogen, led in several types,none were bright, I found there was only 4 volts at the tail/ brake lights, traced the loss to the ammeter, it had rusty nuts , changed the nuts and any of the bulbs were bright ---- the moral is check what voltage you have at the bulb with the bulb on --- with no load on the wire it can show full voltage
Old 11-06-2018, 04:31 PM   #24
JSeery
JSeery's Avatar
An LED is a diode and should be directional. Worse case, reverse the wires on the socket.
Correction: This would be wrong, brain freeze!! You can NOT just reverse the wires on an LED bulb/socket.
Old 11-06-2018, 06:33 PM   #25
coolcoupe
coolcoupe's Avatar
I trying to find around a 50/20 rear brake/tail light bulb. I had bought 2 a couple of years but now need 2 more and can't remember where I bought them
They were a lot brighter than the originals. Moe
coolcoupe is offline   Reply With Quote
Old 11-06-2018, 07:59 PM   #26
uncle buck
uncle buck's Avatar
I went directly to the battery and put the bulbs in a new socket with just the 6" leads coming out of it to double check and see if they were bad bulbs. They only lit up with the socket grounded to the negative terminal. With the socket grounded to the positive and leads to the negative I got nothing.
Old 11-06-2018, 09:50 PM   #27
Jack E/NJ
Jack E/NJ's Avatar
Yep. Reversing the LED wires won't do anything on a dual function bulb cuz one wire goes to the hot brake switch, the other to the hot light switch. If hot is the wrong polarity, LEDs won't work cuz the outside of the base is always to ground, not another wire and not isolated. The LED bulb itself must be internally set up for either positive or negative ground not both. Jack e/NJ
Jack E/NJ is offline   Reply With Quote
Old 11-06-2018, 11:32 PM   #28
JSeery
JSeery's Avatar
Good point!! I was thinking a bit wrong there. The LED is a diode, but as you stated can't reverse the ground through the case!
Old 11-07-2018, 02:21 PM   #29
slowforty
slowforty's Avatar
American Made 1154 Bulbs have Larger Filaments than the bulbs made in another country.
slowforty is offline   Reply With Quote
Old 11-08-2018, 08:32 AM   #30
corvette8n
corvette8n's Avatar
This seems to be a standard #1154 dual filament 6v bulb that is made by many name brand manufacturers like Sylvania. You can probably pick them up at NAPA or Amazon but I'm not sure they'll be any brighter. You can get much brighter 6V LED replacements that fit the standard 1154 base but I'm not sure you want to go that route. Jack E/NJ
The last time I was in my local NAPA buying a 6 volt bulb, the counter guy told me to stock up because NAPA was phasing out 6 volt stuff. The local Advanced Auto down the street said they didn't carry 6 volt bulbs, didn't question just walked out.
Old 11-08-2018, 09:19 AM   #31
oldskool
oldskool's Avatar
what ever bulb is used paint the inside of the taillight white every little bit helps
oldskool is offline   Reply With Quote
Old 11-08-2018, 05:02 PM   #32
uncle buck
uncle buck's Avatar
That is not true. That particular store might phase them out but not all of the NAPA stores.
Old 11-25-2018, 05:56 AM   #33
fortyonerag
fortyonerag's Avatar
Yes, diodes (even light emitters - LED) are supposed to be directional and won't work on +ve ground unless specifically designed for it.
fortyonerag is offline   Reply With Quote
Old 11-25-2018, 06:00 AM   #34
flatheadmurre
flatheadmurre's Avatar
The universal LEDīs have a bridge rectifier built into them allowing you to use either Pos. or Neg. Ground.
I used to gut a lightbuld socket and solder in what i needed myself...but its a lot of work.
Old 11-26-2018, 02:35 AM   #35
fortyonerag
^^^^Thanks
Old 11-27-2018, 04:27 PM   #36
dumb person
dumb person's Avatar
There is a way of building the LED bulbs to be duel polarity using 6 diodes. But most bulbs on the market only have a resistor or crude regulator.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 11-29-2018, 03:39 AM   #37
fortyonerag
Bottom line is there are LEDS that will work with +ve earth and ones that won't. It all depends on how they are constructed.
Old 08-30-2019, 11:01 AM   #38
Merc Cruzer
Merc Cruzer's Avatar
https://www.octanelighting.com/produ...6v-box-of-10-1
I have these in my 53' Merc for turn signal/brake lights and they work great. I also have plastic lenses and no issues after 5 years. No they haven't melted the lenses!
Octane Lighting
675 Cochran St. Simi Valley,
CA 93065
Toll Free855) 962-8263
International: (818) 932-9522
Email: [email protected]
Open: 24hrs
As to LED positive ground bulbs:
https://www.ledlight.com/g18-s25-2_6...-polarity.aspx
Go into the web site, then click on automotive, then scroll down to 6 volt positive ground - three pages of bulbs.
"1154 led bulb for 6 Volt. The led bulb works for both positive ground chassis or negative ground chassis. 1154 LED bulb is a 6v led bulb. Up to 320 Lumen for brake light and up to 240 Lumen for tail light. This bulb is same as 1157 bulb that has two brightness levels or two filaments one is for the tail light and the other is for the brake light. This bulb works great for non polarity 6 volt positive or negative ground."
"After installation of these led bulbs your flasher circuit may hyper flash. Please order part number 84787 which is a 6 volt positive chassis flasher will fix the fast flashing. Please see recommend items for a 6 ohm load equalizer for more information to fix the hyper flashing using load equalizer. This 6 volt led bulb works great for brake lights, tail lights and turn signals."
Merc Cruzer is offline   Reply With Quote
