10-04-2010, 03:54 AM | #1 |
32 steering arm
is the steering arm end on a 32 spindle slightly forward of spindle /kingpin centre from stock or is mine bent?PA041179.jpg
its about a half inch forward at the hole if you straight edge thru spindle and king pin centre ,,,,,,Rod |
10-04-2010, 07:32 AM | #2 |
Re: 32 steering arm
That is the correct orientation of the steering arm. It is not to be bent inline with the axle.
dickspadaro.com |
10-04-2010, 03:54 PM | #3 |
Re: 32 steering arm
thanks Dick for that,,,,Rod
10-04-2010, 03:54 PM | #4 |
Re: 32 steering arm
Thankyou Mr Spadaro for the reply,,,,Rod
10-04-2010, 10:06 PM | #5 |
Re: 32 steering arm
steering gears have been condemned after having one of those adaptors installed. We ALWAYS use the original spindles on 32-34's because that keeps the (properly-oriented) arm, and the above situation is avoided. We still make adjustable drag-links for fine-tuning BUT the original arm also keeps the 90-degree angle between the arm and the drag-link at straight-ahead, so there is equal steering in each direction.
Early V8 Garage Pasadena Roadster Club |
