Old 11-18-2021, 10:04 PM   #1
KULTULZ
KULTULZ's Avatar
Exclamation Bird fan shroud modification
This guy has his stuff in one neat little pile -
https://www.youtube.com/watch?v=T4LslyotK44
PARAGON WP SPACER and TIMING COVER VOLUTE MODIFICATION
https://www.youtube.com/watch?v=q0N9MYW7ND8
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 11-19-2021, 11:21 AM   #2
Patrick brophy
Default Re: Bird fan shroud modification
Fascinating guy.
It is a pleasure to watch someone make something with their hands, rather than buying it.
I was drooling at his tools.
I had read an article about that paragon spacer, but had never saw one.
Patrick brophy is offline   Reply With Quote
Old 11-19-2021, 12:21 PM   #3
KULTULZ
KULTULZ's Avatar
That spacer is the truth when combined with the timing cover volute modification he showed. It would also help PASS CAR (volute mod only).
That combined with a few other modifications/details and one should be able to go.
- WHY IS IT ... -
Old 11-19-2021, 12:36 PM   #4
dmsfrr
dmsfrr's Avatar
To avoid possible confusion,
the improved Ames A-432 water pump spacer only fits in '55 to '57 Y-block T-Birds.
Old 11-19-2021, 02:15 PM   #5
KULTULZ
KULTULZ's Avatar
Question Re: Bird fan shroud modification
Originally Posted by dmsfrr View Post
To avoid possible confusion, the improved Ames A-432 water pump spacer only fits in '55 to '57 Y-block T-Birds.
It will fit any Y-BLOCK but is designed to replace the OEM BIRD SPACER only -
- WHY IS IT ... -
Old 11-19-2021, 05:51 PM   #6
dmsfrr
dmsfrr's Avatar
Yes it will bolt on but,
on a truck or 'full-sized' passenger car the various... fan, water pump and power steering pulleys would need to have their belt alignment checked or changed to match the new forward position of the water pump. Along with after-market air conditioning if equipped.
Old 11-19-2021, 08:03 PM   #7
KULTULZ
KULTULZ's Avatar
... sigh ...
Yes it will bolt on but, on a truck or 'full-sized' passenger car the various... fan, water pump and power steering pulleys would need to have their belt alignment checked or changed to match the new forward position of the water pump. Along with after-market air conditioning if equipped.
Please re-read my post. Everything in it was BIRD related. You are the one that said it was BIRD only. The spacer will fit all FYB timing covers/pumps. Whether that is advisable or not is up to the person using it.
- WHY IS IT ... -
Old 11-19-2021, 10:12 PM   #8
paul2748
paul2748's Avatar
Excellent job on the shroud. However, CASCO has a ready made lower shroud that covers the full bottom half of the radiator (for birds only). I have one of those and it is an exact firt.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 11-20-2021, 10:07 AM   #9
KULTULZ
KULTULZ's Avatar
Post Re: Bird fan shroud modification
... hmmph ...
I did not know that. Now is it metal or plastic and it fits in your opinion as well as the fabricated lower shroud?
- WHY IS IT ... -
Old 11-20-2021, 08:31 PM   #10
paul2748
paul2748's Avatar
Plastic and it fits like a glove. Been on for years with no problems. I have what appears to be a stock radiator. Maybe a fit problem with an aftermarket radiator
Originally Posted by KULTULZ View Post
... hmmph ...
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 11-20-2021, 09:01 PM   #11
55blacktie
I have a U.S. Radiator 4-row copper & brass, still in the box. An aluminum shroud/w electric puller fan is available for same; has anyone used it? I can see where an electric fan would be an advantage when idling, but the cfm rating seems low. Gil Baumgartner (CTCI Gil's Garage) recommends the mechanical fan/w auxiliary electric pusher fan mounted in front of the radiator. If I retain the mechanical fan, I will use Casco's lower shroud.
55blacktie is offline   Reply With Quote
Old 11-21-2021, 03:41 AM   #12
KULTULZ
KULTULZ's Avatar
A pusher style electric fan causes obstruction to air flow through the radiator core.
- WHY IS IT ... -
Old 11-21-2021, 03:47 AM   #13
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Bird fan shroud modification
I noticed in CASCO cataloging that they offer an aluminum radiator with a stamped upper tank. I would hope this was more in appearance to have the rad appear as OEM. I would think their shroud would fit that one correctly.
- WHY IS IT ... -
Old 11-22-2021, 11:55 PM   #14
miker98038
miker98038's Avatar
FWIW, Greenbid56 has an older post(s) over at yblocksforever on fans. He’s done a number of things-the restricted bypass, smaller pulley on the wp, etc. But most important to me is a Hayden fan clutch and a more modern a/c fan bolted to it. He’s got interesting numbers on cooling drop and running temperature at high ambient temperature. Living in Tucson that’s easy to do in the summer.
My bird has gone a number of directions, starting with the original McCulloch supercharger drive pulley. No clearance for a big enough fan. But if I were starting over I’d give his post a hard look. I’ve always been a believer in the clutch fans the oem’s used for years. That and a full shroud has proven it works.
COVID has interrupted my trips south, so I haven’t seen him in a while, but he does know his stuff.
miker98038 is offline   Reply With Quote
Old 12-01-2021, 10:07 PM   #15
CSPIDY
CSPIDY's Avatar
It’s amazing that it took 60 before someone figured out that the Tbird had no coolant flow at idle.
Thank you Mr Chris Ames
CSPIDY is offline   Reply With Quote
