03-11-2023, 06:25 PM | #1 |
Two two barrel 94 setup
Hey guys, I’m running 2 X 2 barrel 94’s. Just saw a video on line of similar set up. His primary carb was the front mine I have the rear, which should it be & does it matter?
Nomad |
03-11-2023, 07:06 PM | #2 |
Re: Two two barrel 94 setup
You should be running them together.
03-11-2023, 07:23 PM | #3 |
With a 2 X 2bbl setup. they should be run together. No primary/secondary
03-12-2023, 01:01 AM | #4 |
jetting and/or power valves ratings ?? Newc
03-12-2023, 07:59 AM | #5 |
Start with 51 jets and 6.5 PVs on a stock flathead, which is what I've run on my '51 for many years, along with straight linkage. There really is no good reason to run progressive linkage on dual 94s or 97s, imo.
03-12-2023, 10:08 AM | #6 |
Also, I asked "CharlieNY" about this for my Navarro "Universal" (a "Super" with exhaust heat) and he said to start with 51 main jets and to plug the power valves. I purchased those items from him. Here is a picture of a "Biased" manifold; note that the front carburetor is very close to the stock location. This type also allows the generator to be mounted in the stock location. Last edited by tubman; 03-12-2023 at 11:41 AM. Reason: Add picture |
03-12-2023, 10:10 AM | #7 |
V8 Bob has it, Good place to start. The worst thing you can do is have aan engine runninr rich in cruise. Once you have the ignitions figgered out, use an AF meter to find the AF in cruise. This should bein the low 14 and above. It's posable to get into the 15's with hicompression and ignition advance.
Gramps |
03-12-2023, 12:15 PM | #8 |
"Also, I asked "CharlieNY" about this for my Navarro "Universal" (a "Super" with exhaust heat) and he said to start with 51 main jets and to plug the power valves. I purchased those items from him."
I've heard this before, but would really like somebody to explain how you get enrichment under a medium to heavy load with stock size main jets and no power system ? I'm not saying it won't work, but just confusing to me. Sal |
03-12-2023, 01:04 PM | #9 |
I have had 2 flat-heads each with the super dual manifolds, 94 carbs setup like V8 Bob and a straight linkage. They worked great. I also ran the larger version of a carb like the 94's set up together on the top of a Roadrunner blown FH and they were set up with a straight linkage. Worked great. All my carbs were built by Baxter Ford Parts in Lawrence Kansas
03-12-2023, 01:08 PM | #10 |
We really should know what type of manifold the O/P has. I would bet that a "biased" type of manifold would run better with progressive linkage the great majority of the time, given the locations of the carburetors relative to the intake ports.
03-12-2023, 01:54 PM | #11 |
It’s much like a slingshot w Both carbs r equal distance centered over intake. I’ll dump the progressive & see if there’s any diff. & report back.
Nomad |
03-12-2023, 02:12 PM | #12 | |
03-12-2023, 02:46 PM | #13 |
I run dual 94s on a thickstun high rise. Actually not 94s, but 2100s which have a 1" venturi.
Straight linkage. Power valves in both but with softer springs than normal, so effectively the equivalent of lower number power valves. I run jets the equivalent of 54s. This is on a 3-3/8 by 4" motor with a hottish cam. I did use an AF meter to get the initial setup. Fallacies: 1, Use smaller jets. Tried that, it ran like crap. 2, Block off the power valves. Hmm, not sure about that. Maybe for all out drag racing, where the jets would be sized for wide open operation and no street driveability intended. I tend to use 'em. 3, Use progressive. Tried that. Couldn't get it to run right. Mart. |
03-13-2023, 03:52 PM | #14 |
There are a few threads on the HAMB that discuss how to set up dual 94s. One fella who has fairly detailed instructions doesn't recommend plugging the power valves.
Here's one of the threads: https://www.jalopyjournal.com/forum/...estions.36751/
WTB '33 Ford parts: * Sedan/Victoria front seat adjuster mechanism * Sedan/Victoria rear seat catch pieces (B-192921 and B-192964) * Sedan or Victoria roof tack strip (OEM or aftermarket) * Straight commercial (pickup) bumper '33/'34 or '35 (46-17757 or 68-17757) |
