10-31-2012, 09:27 AM | #1 |
auxiliary lights and turn signals
I have installed rear lights for safety. I used rectangular trailer lights under the body, and the LED Brakelighter rear window light sold by many model A suppliers. The turn signal unit is from Tickin Through Time, and is a hidden unit with the micro switch on the shift lever.
First photo shows the tail lights on. Second photo show left turn signal. Third photo shows right turn signal. Fourth photo shows brake lights on with out turn signal. With turn and brake lights on at the same time, one side blinks while the other stays on steady. I hate modernizing too much, but feel that with people following so closely, and the fact that hand signals are no longer taught in driving school, that the lights are an added margin of safety. Bill |
10-31-2012, 09:33 AM | #2 |
Re: auxiliary lights and turn signals
Looks good and the main reason that adding signals to mine was the first thing I did.
Paul in CT |
10-31-2012, 09:47 AM | #3 |
How about a picture of the signal on the shifter.
Oklahoma City Model A Restorers Group. |
10-31-2012, 10:05 AM | #4 |
Bill:
I like your setup. However, in the 4th picture, if I were following you and when you applied your brakes, my first thought would be that you might be turning left. I recommend installing a taillight on the other rear fender. Bill Lee/Virginia Peninsula |
10-31-2012, 10:44 AM | #5 |
at last a person put some sensible tail/turn lites on a model a... nice to be able to see them... a nice regard to safety, bill..... thanks.....
10-31-2012, 04:23 PM | #6 |
10-31-2012, 05:26 PM | #7 |
I like that also. Seems to be the best option for me also. Thanks for the pics!
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
10-31-2012, 07:10 PM | #8 |
10-31-2012, 09:33 PM | #9 |
I think the window-mount LED strip is one of the best investments an antique car owner can add to a driver.
Turn-signals are a real close second. Nice job, 2 Many. SC Frank |
11-01-2012, 05:26 AM | #10 |
I just finished mounting the lights on my roadster. I used a second pair of Duo Lamp tail lights on the rear mounted next to the originals ( yes, I did put a 2nd bracket and light on the right side of my A ) and mounted a pair of '32 Ford cowl lights on the front bumper just inside the bumper clamps. May seem convoluted to some but it looks good and is in period for this cars vintage tho' not stock, I know. I'll be wiring things up as soon as my wire arrives from Tams. Going to use a toggle switch mounted on the steering column as the control along with a 6v flasher can hidden somewhere. Works well on my '25 T rdstr pu so we'll see how it goes.
11-01-2012, 07:45 AM | #11 |
People do not know what hand signals are anymore. I put lights on my A too. More than once I was turning left and cars passed me on the left, waving as they did it. They thought I was waving them around!
11-01-2012, 08:14 AM | #12 |
If you're going to add trailer lights, why not just use them? Gives a cleaner, more efficient job to my eye, with the signals coming from where other drivers expect them to come from--no mixed signals. Model A guys know they're not authentic, but most other folks don't, unless they study them up close. Extra lights added just scream non-authentic to me, not that I'm personally opposed; I've also got the rear window brake light and motorcycle turn signals up front. Here's my trailer lights, which have the extra advantage of side illumination. SAFETY FIRST.
11-01-2012, 08:33 AM | #13 |
On my 30 std. roadster I used 67 VW amber backup style lights mounted under the rear body on brackets from the bumper supports and added cowl lights(optional on std.roadster) only for directionals in the front. I plan to paint the front bulbs amber and leave the lenses clear.
11-01-2012, 09:45 AM | #14 |
I did almost exactly the same thing to my 30 coupe a month ago.They do seem to help people approaching you from the rear know what you are going to do .I think they all need safety lights on the back.The originals are so hard to see
11-01-2012, 12:49 PM | #15 |
Here are the photos of the switch and the unit. The unit attaches to the inside of the firewall with velcro. It has connections for front and rear lights, brake signal input, power, and ground. The red wire is the fused power wire. The black wire is ground. I just wound the phone cord from the switch around the flasher for now, will make it neat later. The buzzer is on the right, and is noisy enough to eliminate an indicator light.
I put the rectangular trailer lights under the body so they would not look bad when not in use. They are not noticeable until lit up. The original brake light is still in use, and I dont see that as a problem when braking, as it does not blink, like a signal does. I figure this is much better than no lights, and I dont want a right side taillamp, as the 29 did not come with one, and I like my hidden lights better. The light in the rear window is very slim, and not terribly noticeable until lit. I am not suggesting everyone should do what I did, or that this is the best option, I just posted to show what I did, and what can be done. Everyone has their own idea as to what they think is best. |
11-01-2012, 04:30 PM | #16 | |
11-02-2012, 09:10 PM | #17 |
We've found driving without indicators and decent brake lights a bit daunting (especially since after our last drive, we discovered the rear light doesn't go at all now!)
We've bucklaed under the pressure, and are going to drill the 3 holes in the other fender to add another tail light. I'm going to install a repro bracket, and tail light with amber top on each side. I'm also going to ad a 32(?) tail liaght on each side (the ones with one big read lens). The amber section will be the indicator, the tails will remain the same, and the 32 light will be the brake light. It will be a bit messy, but the lights are at least from the correct "period" and are similar in design. I think I'll get a pair of 30's comercial cowl lights for the front indicators, and ad amber bulbs to them. Hopefully it looks OK :-) Cheers,
Allan '29 Tudor, Canadian RHD Whangarei, NZ "Duct Tape can't fix stupid, but it can MUFFLE the sound" Last edited by Allanw; 11-02-2012 at 09:11 PM. Reason: typo! |
11-02-2012, 09:51 PM | #18 |
I installed the right tail light bracket and then installed LED Tail/Brake lights in them. I also installed LED directionals in the front and rear bumpers. Members of my club have told me they sure look good when braking or directionals are on. I'm not worried they are not original as I feel it is a safety thing.
11-03-2012, 09:36 AM | #19 | |
11-04-2012, 04:31 AM | #20 |
Those lights blend in surprisingly well, considering the square shape!
We weren't going to fit lights, but then decided that a few etra holes in probably better than a written off "A". There are some serious retards on the road around here! You have to cater for the eisting dangers, AND them! Have ordered a bunch of stuff... I'll post up some pics when we've done it all - probably in a years time
Allan '29 Tudor, Canadian RHD Whangarei, NZ "Duct Tape can't fix stupid, but it can MUFFLE the sound" |
Thread Tools | |
Display Modes | |
