Old 07-30-2021, 07:25 PM   #1
std1940
std1940's Avatar
Default 1940 Coupe side quarter glass installation
I am replacing the seals around the side quarter glass on my 40 coupe.
What are you using to take up space to make the window seals fit snuggly between the inner garnish moulding and outer body?
Mine did have something like 3m (8578) strip caulk between outer seal and body.
I am looking for something better looking and more rigid.
Thanks Tom.
std1940 is offline   Reply With Quote
Old 07-30-2021, 08:30 PM   #2
Kube
Kube's Avatar
Default Re: 1940 Coupe side quarter glass installation
Tom, I had found this very same issue when a client sent me Sanders glass for his restoration. It was much thinner the stock glass. As I recall, nearly .030" thinner.
I prefer having my glass to be cut locally from the correct stock.
Regardless, I utilized black electricians tape to build up the required thickness and along with the rubber seal placed over the tape, the glass fit snug.
Old 07-31-2021, 10:02 AM   #3
19Fordy
19Fordy's Avatar
On my 40 I used the item shown. You apply it after the glass and garnish molding is installed. I applied it with my finger and it smooths out really nice. Easily wipes off with gasolene. I used this product because I didn't want water to seep between the garnish molding and body or "cloud up" the glass over time. My quarter window glass is the correct thickness.
I am pretty sure I read on Fordbarn that no such "filler" was used at the factory install.
Therefore, may not meet AAA standards.
Read everything here, including the links.
https://www.fordbarn.com/forum/showt...er+window+seal
Old 07-31-2021, 04:08 PM   #4
std1940
std1940's Avatar
MIke, My glass is from Sanders going back to 1984 and I have the original glass also.
I measured both the old and new and they measure the same 1/4".
I feel the glass fits snug enough in the rubber seal but not snug enough between the inner garnish moulding and the body.
I will try what you suggested.
Thanks Tom.
Old 07-31-2021, 05:21 PM   #5
lgndlt5
Thanks Tom.
Hi Tom. Just a thought. I recently purchased a back glass seal 36 sedan from C&G it is a black “U” channel with 3 square sides it might do the trick if you are looking for filler. $14.95. It seems you could cut it to length and trim as needed to fill the gap behind the window trim it may be a clean solution. Just an idea good!!
lgndlt5 is offline   Reply With Quote
Old 07-31-2021, 05:56 PM   #6
TJ
TJ's Avatar
On a couple of '40 coupes where I replaced the original glass I found some old hard black stuff between the rubber and the body. It looked like old dried "dum dum" type stuff. i don't think that the stuff shown by 19Fordy is available . Napa used to carry it and it is no longer available. It's possible you could use 3M Strip Caulk or 3M Window Weld. The strip caulk has some oil in it so you have to keep it away from any fabric.
