07-30-2021, 03:27 PM | #1 |
1936 Ford Pickup Fender Braces
Hey Guys,
I've got a 1936 Ford Pickup that I probably bought 40 years ago and tore-down 30+ years ago. I bought one new front fender brace and a pair of rear fender braces from Early Ford V8 (SC). The front brace appears to be the same size as my original brace, but the bend isn't even close. I can deal with that using a hammer and maybe a little heat. I had no rear braces and can remember how the rear fenders would flutter in the wind. The ones I received look like they'd fit a 12" wide fender, whereas mine are about 10.5". I do not know where these attach. Could someone give me some advice and maybe a photo or two of where and how these braces are suppose to attach? While you're at it, how about a photo of where the front of the rear fender attaches. I assumed they would bolt to the rear of the running boards, but the bolt-hole size and number don't match up at all. Does something go between the running board and the rear fender? Look forward to any information. Thanks |
07-30-2021, 11:46 PM | #2 |
Re: 1936 Ford Pickup Fender Braces
Hope these pictures help. This is the drivers side outside fender to rear brace. A carriage bolt is used.
07-30-2021, 11:54 PM | #3 |
This is a picture of the inner attachment
Sorry -- picture would not load Please note that the fender braces do not fit the contour of the fender. |
07-31-2021, 04:39 PM | #4 |
Here is a photo of the rear fender bracket I received. It's sitting atop a 12" square. My fender width is 10.5", while this bracket is 12" wide. What am I missing?
Thanks |
07-31-2021, 07:50 PM | #5 |
