Old 04-17-2020, 05:25 PM   #1
Borninthefifties
Default Model A ID
Is there a definitive way to determine whether my 31 coupe is a standard or deluxe?
Borninthefifties is offline   Reply With Quote
Old 04-17-2020, 06:06 PM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Model A ID
If it doesn't have cowl lights , its a standard model .
Old 04-17-2020, 06:12 PM   #3
FordTudor1931
FordTudor1931's Avatar
Arm rests in the back seat and dome light would be Deluxe.
FordTudor1931 is online now   Reply With Quote
Old 04-17-2020, 06:48 PM   #4
redmodelt
redmodelt's Avatar
"coupe"
Old 04-17-2020, 07:57 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
delux has dome light
Old 04-17-2020, 08:34 PM   #6
Ruth
The big question is did it start out life as a standard or deluxe coupe.
Ruth
Old 04-18-2020, 08:32 AM   #7
Woodys29
Deluxe coupe also had wood grain dash and window trim.
Woodys29 is offline   Reply With Quote
Old 04-18-2020, 09:11 AM   #8
rotorwrench
rotorwrench's Avatar
Roll down back light window?
Old 04-18-2020, 10:05 AM   #9
Borninthefifties
Aloha, Thanks for the responses. I'm no expert, but this car seems to be mostly original, She has cowl lights and a dome light but no wood grain dash or roll down rear window. Were the lights options on a standard?
Old 04-18-2020, 11:21 AM   #10
1930artdeco
1930artdeco's Avatar
It is possible to order options at the dealer. But what it sounds like is that someone optioned the car later in life. Up to you to keep going or revert back.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 04-18-2020, 02:38 PM   #11
rotorwrench
I'm sure more than a few folks have upgraded their cars over the years.
Old 04-19-2020, 10:05 AM   #12
Badpuppy
Two-bulb headlight reflectors would make it a standard, if they're known to be original. Dome light is tough to add by itself, but not impossible.
Badpuppy is offline   Reply With Quote
Old 04-19-2020, 02:14 PM   #13
Borninthefifties
Aloha, Not sure what you mean by two-bulb headlight reflectors. Several people have mentioned the dome light. If this is an original factory dome light does that make my car a deluxe? What about wind wings? My car has upper and lower brackets on both doors. Was this a factory option or a dealer add on?
Thanks again
Old 04-19-2020, 03:11 PM   #14
Purdy Swoft
Two light reflectors had an extra socket for the park lamp bulb . Standard models that didn't use cowl lights had the park lamps bulbs in the headlamp reflectors .
Old 04-19-2020, 03:31 PM   #15
Charlie Stephens
Attached photos to illustrate Purdy's post. This is a 2 bulb reflector, there is only one bulb for a deluxe car as it had the second light as a cowl light. The reflectors should have a mirror like surface but a tarnished one photographs better.
Charlie Stephens
