08-01-2021, 09:07 AM | #1 |
'46 Ford column shift lever disassembly pin
Need help on how to remove the shift lever from the column shifter "T" joint.
There seems to be a spring loaded cap at the top but not underneath. I want to inspect/ replace all the parts in the assembly going down to the shifter arms at the lower end. Thanks, Larry |
08-01-2021, 09:27 AM | #2 |
Re: '46 Ford column shift lever disassembly pin
This might help.
08-01-2021, 10:45 AM | #3 |
Remove the pin # 7337 first.
08-01-2021, 11:19 AM | #4 |
Thanks guys , for all of your help--- Larry
08-01-2021, 05:47 PM | #5 |
Diagram - Gear Shifter Linkage for 1948-52 Ford F-1 Trucks |
