Old 02-09-2021, 04:50 PM   #1
jerbo
Default How to clean our inside cast sediment bowl?
Does anyone have a way to clean out the old rust from inside the cast iron sediment bowl without damage to the surfaces where the screen slips over?
Thanks for looking, Jerbo
jerbo is offline   Reply With Quote
Old 02-09-2021, 05:35 PM   #2
alexiskai
alexiskai's Avatar
Default Re: How to clean our inside cast sediment bowl?
Would Evaporust work?
Old 02-09-2021, 05:43 PM   #3
Bob C
I use Rust 911, comes out looking like new. If it's really bad it
may take a couple of soakings. I bought a pyrex bowl and a desktop
coffee cup warmer for use in the winter as the solution doesn't work very well in cold weather.
Old 02-09-2021, 06:06 PM   #4
Steve Plucker
Also bead blast or sand blast the inside.
Pluck
Old 02-09-2021, 06:42 PM   #5
Gene F
Gene F's Avatar
Can ya get 00 steel wool in there? I know it sounds like work, and odd, but sometimes those old ways are best. Of course get all the strands out when done. I've seen my grandad clean up wheel cylinders with steel wool before putting a kit in them before.
Gene F is offline   Reply With Quote
Old 02-09-2021, 06:51 PM   #6
Blue-Truck-Nut
Blue-Truck-Nut's Avatar
Sounds like a candidate for the molasses solution.
Mix 3 parts water to 1 part molasses, submerge the part. If it's not too bad an overnight soak may be enough, if it's real bad it can take days. Rinse off with water and dry or it will rust again in short order.
Sent from my E6810 using Tapatalk
Blue-Truck-Nut is offline   Reply With Quote
Old 02-09-2021, 09:54 PM   #7
Dan Partain
Dan Partain's Avatar
To clean part of it, check out this video.
https://www.youtube.com/watch?v=M9ECeK_xf1c
Dan Partain is offline   Reply With Quote
Old 02-09-2021, 09:58 PM   #8
SteveB31
SteveB31's Avatar
Buy 5 gallons of evaporust. You can use it for this and many more things.
SteveB31 is offline   Reply With Quote
Old 02-09-2021, 10:52 PM   #9
CWPASADENA
CWPASADENA's Avatar
X2,
You can also use Evaporust but Rust 911 is a lot more economical.
I do not recommend sand or bead blasting. It is just about impossible to get all the sand or beads cleaned out.
My experience and my opinion.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 02-10-2021, 01:04 PM   #10
katy
katy's Avatar
Sodium hydroxide, aka lye.
Old 02-10-2021, 01:08 PM   #11
WTSHNN
WTSHNN's Avatar
Evaporust.
No one wants advice - only corroboration.
-John Steinbeck
WTSHNN is offline   Reply With Quote
Old 02-11-2021, 02:17 PM   #12
mass A man
mass A man's Avatar
Please only use a chemical rust remover! The inside of that cast bulb is a rough sand casting with a small seam,nearly impossible to ever get any sand out. It will wash through to your carb jets eventually.
mass A man is offline   Reply With Quote
Old 02-11-2021, 02:27 PM   #13
McMimmcs
McMimmcs's Avatar
Pluck
Many people believe as do I that sand blasting is not a good idea because it is very difficult to get all the sand particles out.
McMimmcs is offline   Reply With Quote
Old 02-11-2021, 03:05 PM   #14
1928Mik
1928Mik's Avatar
I take my carb off at least twice a year and spray it out along with the cast sediment bowl and screen using Valvoline Carb & Throttle Body Cleaner. Works great for me!
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible
1979 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 02-11-2021, 04:44 PM   #15
JayJay
Jerbo - Here's another vote for EvapoRust, I love the stuff. In my experience it takes longer than the label suggests, it's not at all unusual for me to leave things soaking overnight for heavy rust. Also, every couple of hours I take a toothbrush and scrub off what has already converted so that fresh rust (is that an oxymoron?) is exposed to the chemical. (For those wise-guys out there, no I don't get up in the middle of the night to do this!)
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
JayJay is offline   Reply With Quote
Old 02-12-2021, 10:36 AM   #16
katy
katy's Avatar
Molasses and water mixture also works for rust removal.
Old 02-12-2021, 08:38 PM   #17
henry's 31
I echo what Bob C states, Rust 911 does an incredible job removing rust from anything including gas tanks and radiators.
Henry' s 31
henry's 31 is offline   Reply With Quote
Old 02-13-2021, 11:43 PM   #18
Certimafied
Certimafied's Avatar
I purchased a can of carb dip to clean out my Tillotson and a Rochester For a different project. When I was done I gave the sediment bowl a dip for a night. Rinsed it out used lots of air pressure to blow it out, had to repaint after the dip, no biggie tho.
No problems so far I’m a couples tank of gas in now!
Certimafied is offline   Reply With Quote
Thread Tools
Display Modes
