01-22-2021, 03:29 PM | #21 |
Re: ultimate flathead
Boy am I glad the guy never raced at Bonneville with so much horsepower and RPM's from that 239 cube flathead the records would be REALLY high and no one would be able to touch them. LMAO
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
01-22-2021, 03:30 PM | #22 |
"Was" as in used to be, but now in pieces
01-22-2021, 04:43 PM | #23 | |
Here is a pic of that setup with the tattletale at 9300. Really gets the fans talking after the race. This was a fairly stock 4 banger. |
01-22-2021, 07:40 PM | #24 |
This is the part of the whimsical story that got my eyes rolling...
"This is a steep hill which goes from sea level to 1500-feet elevation in less than seven miles. I punched the throttle and away we went: 50 mph, then 70 mph, then 90 mph. The numbers stopped at 90 mph but the needle kept climbing around back to 0 again, then 10, 20, and finally 30 mph on the second time around."
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? Last edited by VeryTangled; 01-23-2021 at 08:22 AM. Reason: Spelling |
01-22-2021, 07:46 PM | #25 |
Sometime after that I was out to Barger-Mattson wrecking yard and found a blown 350-cid Corvette engine in the inventory. I bought the camshaft, heads, distributor, intake manifold and carburetor and commenced to put them on my engine. What a difference in power that made. It still didn’t match up to the flathead I used to have, but it was about 50 percent better than the stock 283. The only problem was that the carburetor was a 750-cfm Quadrajet and while a 350 might handle that, the 283 would not. I ultimately pulled off the intake manifold and carburetor and put a 4GC Rochester in its place, then everything worked like it was supposed to. Later on, I pulled the manifold off again and put a 2GC Rochester carburetor on it as the 2GC was easier to work on than the 4GC. Since I only drive the ’32 about once a year and I don’t do much hot rodding anymore, that is about all I need. When I put the Chevrolet motor in the ’32, I found that, while the flathead with its high revolutions handled the 4.44 differential OK, the 283 did not so, again, I changed differentials and went back to the 3.78 ratio, which the 283 handles OK.
This story is like a car wreck. I can't stop looking at it. This passage is just too good to not share. Even includes the mandatory bench racing equivalent of the cherry on top: The Corvette SBC. Nothing else will do. |
01-22-2021, 08:40 PM | #26 |
01-22-2021, 08:58 PM | #27 | |
One of my favorite Shades stories is when he was driving his '72 SBC powered Chevelle down Rt. 22 in Easton, PA in a race. At 120, he realized he wasn't in fourth. Once he "slammed it" into fourth, he estimates he topped out at 160. I guess this BS works on some folks, but to have such a bullsh*t story published in a magazine is a bit surprising. |
01-22-2021, 11:28 PM | #28 |
Just wondering if it was April 1st? I didn't read the story. You guys provided more than enough info for me.
01-23-2021, 08:19 AM | #29 |
I read that story and I think he forgot to take his prevagen before he woke up.
01-23-2021, 10:07 AM | #30 |
My guess, made about 120 HP and started seriously wheezing by about 5000 RPM . . .
01-23-2021, 02:24 PM | #31 |
Just cause it's printed in a magazine doesn't mean it's true.
01-23-2021, 02:42 PM | #32 |
If BULLSHIT was Money, then this guy is a Billionaire
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
01-23-2021, 02:55 PM | #33 |
Haters gonna hate, I guess.
To the youth reading this, always remember that anything is possible. Heck we even put a man in space only a few years later.
"Sometimes he would accuse chestnuts of being lazy, the sort of general malaise that only the genius possess and the insane lament." |
01-23-2021, 04:11 PM | #34 |
Yeah, but it damned-sure weren't with no 12,000 RPM flathead! DD
01-23-2021, 09:46 PM | #35 |
Our strictly strip flathead hit 6,000 on a good day, but made me nervous. 350hp at 10,000rpm ain't gonna happen with that engine.
01-23-2021, 10:04 PM | #36 |
This is just a store in the vain of Paul Bunyan.
01-24-2021, 03:37 AM | #37 |
they dont buildem like that any more
01-24-2021, 09:03 AM | #38 |
01-24-2021, 01:02 PM | #39 |
Aw, come on guys, the truth of the matter is that a flathead is superior to a sbc.
01-24-2021, 01:37 PM | #40 |
