Old 01-19-2021, 03:16 PM   #1
friz2u
Default front fender brace straightening
My 29 front fenders don't line up good with the forged braces. Is there anything that I can use as a guide or do you just shoot from the hip and bend to fit properly? Thanks
friz2u is offline   Reply With Quote
Old 01-19-2021, 04:38 PM   #2
Brentwood Bob
Default Re: front fender brace straightening
Use the light bar as a guide?
Brentwood Bob is offline   Reply With Quote
Old 01-19-2021, 04:46 PM   #3
Oldbluoval
Oldbluoval's Avatar
Bobs correct
Using a press works better but it takes.a bunch of
“Off and ons” and trial fittings
Old 01-19-2021, 05:30 PM   #4
Cape Codder
Cape Codder's Avatar
BUT, how is the curve in the light bar determined AND length?
Cape Codder is online now   Reply With Quote
Old 01-19-2021, 05:36 PM   #5
Oldbluoval
Oldbluoval's Avatar
Mostly 29 light bar is straighter than 30-31
Lay it out and see if it’s symmetrical
Old 01-19-2021, 09:02 PM   #6
friz2u
the light bar fits perfectly. I thought there might be a template available or something like that to go by.
Old 01-19-2021, 09:23 PM   #7
mrbilman
Since the light bar fits you have half the battle won. I had to do a lot of tweaking to get the fender braces to fit and was happy to find that the metal does bend nicely. Trial and error and take it slow. I'm not aware of anyone that makes templates and even if they existed they probably wouldn't fit either.
mrbilman is offline   Reply With Quote
Old 01-20-2021, 03:55 AM   #8
john charlton
john charlton's Avatar
I have solved this problem by fitting the fenders, light bar and braces "loose" then you have wiggle room for fitting .Once everything is loosely connected it will all pull together when you bolt it up .
John in Suffolk County England .
Old 01-20-2021, 09:56 AM   #9
KenBolton
Yes, what John said. And then it is still a challenge! I wouldn’t know how perfectly these things fit originally at the factory but my guess is the tolerances where wide. I still get tickled when I remember reading about adjusting a body part later in the 30’s in the service letters. It essentially said;”Get a big hammer and beat it until you get the right curve”.
KenBolton is offline   Reply With Quote
Old 01-20-2021, 03:15 PM   #10
Kevin in NJ
First off, NO the parts were NOT poorly fitted.
Ford did not want people wasting time on the floor fitting parts. It cost time and money. So most of the production part were much more precision fit then you might think.
When fitting fenders you first fit the light bar to the braces. I spent a few hours adjusting the light bar and braces until the bolts just fit in easy. Yes, there is a magic spot where they just fit together and until you hit it the bolts do not go in well. I cold bent the light bar in a vice by hand. The braces I did cold with a short piece of pipe that would go over the brace and let me put in a long metal lever.
Once you have the braces correct for the light bar you now fit the fender. The fender is fit to the frame edge and then you have to figure out how to reshape the fender to fit the light bar postion. Again a lot of change, fit and step back to see the 2 fenders are even. If the bead line has been welded then all bets are off on getting anything to fit. You will have to cut the bead line and make it all work. Just a small change in the bead line will make the whole fender shape wrong.
Ultimately the bead should be straight and vertical from the bolt to the bolt and along the running board. So you also have to align the running board brackets. It is a system that has to fit together.
Keep in mind I am doing a 31 body.
Later I bought a pair of NOS fender brackets. I made a jig from them to see how close the brackets I adjusted on the car to the light bar came to factory. They were dead one, well one side the bead was off a bit, but that I knew because the fender had be worked by someone else off the frame and some curves were messed up. Off the car you would have paid premium price for clean rust free fenders. Both had been accident victims but no bead cracks and both had been kinked. I found this out when I sand blasted them.
While all the above seem complicated. It took me some time to figure it out, but in the end it was not very hard to do.
Old 01-21-2021, 08:20 AM   #11
friz2u
Thanks to everyone, I got them fitted together and it looks great!
