Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 11-03-2020, 12:16 AM   #1
Ronken
Default 1951 Ford F1 flathead to T5 (Transmission Mount)
Hello, Have a 1951 Ford F1 with a stock flathead and would like to install a T5 transmission. Am puzzle about the transmission mount. Does anyone have any pictures or suggestions on a transmission mount. Have thought about cutting out a space on the original crossmember and welding a plate to the cut ends and then bolting a channel to the 2 vertical plates for the mount. |_|
Regards, Dan
Ronken is offline   Reply With Quote
Old 11-03-2020, 10:47 AM   #2
redmodelt
redmodelt's Avatar
Default Re: 1951 Ford F1 flathead to T5 (Transmission Mount)
This section is not for car questions, it's for issues with the site. You need to ask on the Early V8 forum or as this is a mod you might try H.A.M.B. over on Jalopy Journal
https://www.jalopyjournal.com/
