08-20-2018, 07:44 AM | #1 |
Mitchell and 3.54 gears
Anyone running this combination?
I've ordered one (for a 32) and hoping will keep the engine to around 2200rpm at 70, it doesn't like running at 3000rpm for 7 hours on the motor(free)way. Thanks in advance for any replies. |
08-20-2018, 09:32 AM | #2 |
Re: Mitchell and 3.54 gears
I would think you will be practically at an idle at 70! does the 32 have enough clearance to the floor for the Mitchell? I wanted one for my 34 but from my measurements it would hit on a good pot hole. Ken
08-20-2018, 10:22 AM | #3 |
mine do hit . just go to 3.54 gear in rear end
08-20-2018, 10:51 AM | #4 |
I'm running 3.54's in a 1930 Roadster. I think that a Mitchell would be a nice addition.
I would go for the lower ratio overdrive. (Said with no experience). Karl |
08-20-2018, 10:57 AM | #5 |
3.54s with a Mitchell would make that flathead fall flat on it's face. Do either the 3.54s or the Mitchell , but not both.
08-20-2018, 10:58 AM | #6 |
08-20-2018, 11:23 AM | #7 |
Have you considered going to a 3:23 ring and pinion? Taller rear tires?
08-20-2018, 11:54 AM | #8 |
I run a 36% with a 4:11 on a 37 21 stud flathead. However no hills in Houston,TX area.
41 woodie https://41fordwoodie.weebly.com/ |
08-20-2018, 12:05 PM | #9 |
Thanks for the comments, based in Scotland its a long drive to most shows so 7 hours at 3000rpm isnt good - a lot of oil! Even with 3.25 gears would stil be too high, neighbour next door has a 35 with 4.11 and Columbia and 284 flathead like mine and his is nice at 2200rpm / 70mph. I reckon the torque will keep it moving too. Clearance should be ok. The unit should be shipped November time so will put photos up.
08-20-2018, 12:07 PM | #10 |
As I read your last post, you are running a 284" engine. Big difference from a stock 32 with 65 HP. You're probably good to go with that engine.
08-20-2018, 12:28 PM | #11 |
I have a very heavy(3675 lbs. with me on board) 40 two door with 276 engine and a/c. I have the Mitchell they call 36%(but it is NOT) and 3.78 gears. I sure wish I had 3.54 gears AND the Mitchell.
08-20-2018, 01:05 PM | #12 |
A buddy of mine put 3:23 in his 40 Ford sedan and what a dream to drive. We live in hilly country and no problem pulling the hills. He has a stock engine. I WOULD NOT BE AFRAID OF 3:23 gears in a 32.
08-20-2018, 02:26 PM | #13 |
That's the combination that I have in my A V/8. Works great. Ed
08-20-2018, 02:35 PM | #14 |
Well that all sounds like a plan, hopefully it won't get dropped of the ship in the Atlantic.......Will post photos when doing the work.
08-20-2018, 02:40 PM | #15 |
Assuming 29” tires and overdrive of 26% it would be 2109rpm at 70 with 3.54.
Here is one of the easier speed,rpm calculators. Enter 3 values and solve for 4th. http://www.advanced-ev.com/Calculato...Size/?speed=70 John |
08-20-2018, 02:58 PM | #16 |
Thanks John, appreciated.
08-24-2018, 06:31 AM | #17 |
I have a stripped down Model-A roadster with a hopped up model-B engine... it has 3.54 rear gears and a home made overdrive in the torque tube... the problem with mine is that it also has Lincoln transmission gears so its not as snappy feeling off the line.... I also have 7.00x16 rear tires... I can pretty much idle at 65 or so down the road.
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads |
08-24-2018, 12:00 PM | #18 |
My 36 has a well built 59AB engine, the differential is a 46-48 Columbia with 3.78 gearing, 600x16 tires. I tried 26 tooth Lincoln gears in the trans in my '36 for a very short while, big mistake. The car was totally gutless. I went back to a 28 tooth gear set and decided to leave the gearing alone..
Bill.... 36 5 win cpe |
09-06-2018, 02:40 PM | #19 |
I have 3:78's and the 36% mitchell in my '47 with a max 1 cam and two carbs. I think if you are after highway you'll be happy with the 3:54.
09-06-2018, 02:55 PM | #20 |
Hello Mr. Stud. Can you give us a RPM comparison, in and out of overdrive, at a given road speed?
