04-10-2021, 04:40 PM | #1 |
How to shorten a bolt Mart's way. Includes some pain and bonus outtakes!
Hello! Welcome to a handy tip courtesy of Mart at Mart's Garage.
This is a method of shortening a bolt that worked well for me. I thought it would make a handy tech tip short stand alone video so I fired up the camera. Well, watch along and see how it panned out. If you're wondering, I didn't hurt myself badly. Mart. https://youtu.be/rBbnyPYuMaI |
04-10-2021, 07:39 PM | #2 |
Re: How to shorten a bolt Mart's way. Includes some pain and bonus outtakes!
Perfect - sometimes (depending on the bolt material and size) I'll take the file and file the nut flush with the bolt and then proceed with your steps. Sometimes I'll even put it on the grinding wheel. One last thing I usually use two nuts on it so I can lock them in place. All depends on how picky I need to be. Thks for the video
04-10-2021, 09:00 PM | #3 |
I liked the video too. I am a big fan of nylock nuts so I often add a couple of washers under the nut for cutoff.. That way the nylon insert is allowed to come into play when the final nut is installed. As often stated, the nylock won't pass judging at a points meet, but I like how they feel when I crank them down. Verrrry bumby roads where I live.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
04-11-2021, 09:38 AM | #4 |
That's the way I do it.
I even rack my knuckles on the vice too. |
04-11-2021, 05:32 PM | #5 |
Didnt know there was any other way. Was expecting you to do an elegant lathe job ........
04-11-2021, 06:35 PM | #6 |
