06-13-2016, 05:45 PM | #1 |
Is there adifference between an "A" or "B" head gasket
Due to a supplier mix up I think I will be receiving a head gasket for Model B instead of a Model A. Is there a significant difference between the two?
Thanks again for all of your help. |
06-13-2016, 07:42 PM | #2 |
Re: Is there adifference between an "A" or "B" head gasket
Our newly produced one does both plus hi comp heads, copper
06-13-2016, 08:33 PM | #3 |
I use a copper "B" gasket on my high compression "A" head with "A" block. I think it is the ideal combo! Ron W
06-13-2016, 09:10 PM | #4 |
06-14-2016, 02:14 AM | #5 |
I have a B block with an A head. Which gasket would I need?
06-14-2016, 07:30 AM | #6 |
06-14-2016, 08:16 AM | #7 |
It is a stock A block with a stock head. I guess I will just refuse the shipment and re- order from another supplier. Thanks guys, you are the best.
06-14-2016, 09:01 AM | #8 |
Sooo, what is the difference between A and B head Gaskets?
06-14-2016, 09:41 AM | #9 |
The original B gaskets have a narrower than A "waist" area between the valves and the cyl. This made the gasket hang out into the A combustion chamber, not good. Not sure about modern B gaskets. The gasket must fit both the head and the block.
06-14-2016, 10:23 AM | #10 |
Not sure why, but Snyder's instructions with their 5.5 A head say to use a B gasket.
06-14-2016, 10:48 AM | #11 |
06-14-2016, 11:07 AM | #12 |
06-14-2016, 03:14 PM | #13 |
The A gasket can overhang the chamber around the valve area on hi comp head , not ideal , A B gasket does not , don,t ask how I know , check when installing 1st , just cause it fits the block does not mean it fits the head,
06-14-2016, 05:03 PM | #14 |
Use a model A gasket and plug the steam holes in the middle of the deck.
06-14-2016, 05:23 PM | #15 |
06-14-2016, 08:01 PM | #16 |
quickchange is dead on.
If any part of the gasket hangs into the combustion chamber, it will burn up and fail early. The B gasket is scalloped out better around the valves to match the high compression heads, which have relief around the valve area for better breathing. To run correctly , a motor needs 1. compression (head) 2. breathing (valves and cam) 3. timing (dizzy) these 3 areas need careful attention The dynamics of a running motor must be taken into account carb is easy compared to above......
'31 180A |
06-14-2016, 10:11 PM | #17 |
James NO its a hi comp head ,cast snyders have less meat around back of valve area & normal felpro A will overhang, may not blow but will make engine sound harsh, I know , been there done that , do agree about blocking the two holes , but if using the B or our new one no problem,
