05-28-2016, 10:49 AM | #1 |
Compression test - cylinder head
My compression test results: 85,86,86,89 (psi)
I notice others post numbers in the 50's. Does that mean I have an other than stock cylinder head? It's not aluminum. I have a '30 engine (stock, as far as I know) in a '29 Tudor. |
05-28-2016, 11:00 AM | #2 |
Re: Compression test - cylinder head
Yes. Ron W
05-28-2016, 11:06 AM | #3 |
And you should be HAPPY.
05-28-2016, 12:20 PM | #4 |
Your gauge may be loose
05-28-2016, 12:35 PM | #5 |
we just had a friend do a 28 standard head, 63,63,64,64 and with a compression ratio of 4 to 1 figures are good.
Richard in New Bern. When everything seems to be going against you, remember that the airplane takes off against the wind, not with it” - Henry Ford |
05-28-2016, 12:35 PM | #6 |
I get the same readings on a 6.8 to 1 Winfield aluminium head And try another compression tester just to make sure.... |
05-28-2016, 12:36 PM | #7 |
05-28-2016, 12:46 PM | #8 | |
Your compression ratio is only up around the 5.5 to 6.0 range. Regular fuel is fine for that. If you hear the engine knock climbing a steep hill, retard the spark a tad (about 1/4 of the quadrant travel) and the knock should stop. Your compression numbers are quite close to each other, so I'd say all is good. Just go drive it and have fun!!!
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
05-28-2016, 12:58 PM | #9 |
Pics of head:
05-28-2016, 01:06 PM | #10 |
That first picture is a good one to show the bellcrank for the throttle linage, to show the angle it rests at. This would be for the person that showed a welded link the other day, and was having trouble.
Why such a tall stud on the water outlet? |
