Old 05-10-2016, 10:20 AM   #1
COOTER
Default Downdraft question
Could a U-shaped adapter be bolted to a stock A intake to run a downdraft carb?
COOTER is offline   Reply With Quote
Old 05-10-2016, 10:27 AM   #2
George Miller
George Miller's Avatar
Default Re: Downdraft question
Maybe but why. I would not help. You would be better off to plug the bottom and weld a adaptor on top. Better yet get a down draft manifold.
George Miller is offline   Reply With Quote
Old 05-10-2016, 10:34 AM   #3
COOTER
So, is it the downward flow of fuel or the type of carb that makes it better?
I do not have the skill to weld cast iron.
Old 05-10-2016, 11:26 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
If you want to "build" your own manifold, a stock one can be flipped UPSIDE DOWN.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-10-2016, 11:50 AM   #5
Jim Brierley
It is the size of the carb that makes them better, bigger is better. Bigger equals more air flow, so more air/fuel into the engine gives more power.
Jim Brierley is offline   Reply With Quote
Old 05-10-2016, 12:00 PM   #6
COOTER
Bill W.
Any pics of someone running a flipped manifold?
Old 05-10-2016, 12:07 PM   #7
100IH
Problem is the carb won,t work if upside down. Curves are your enemy for the air flow.
100IH is offline   Reply With Quote
Old 05-10-2016, 12:29 PM   #8
COOTER
Not wanting to run a stock carb upside down. Probably gonna run a carb from a flat 6. So, it won't like the curve of a U-shaped manifold?
Old 05-10-2016, 02:12 PM   #9
George Miller
No it won't like it. But is about a lot of things. The bore in the manifold is to small. To make it really work takes a lot of things to work to gather.
Old 05-10-2016, 02:35 PM   #10
mike657894
mike657894's Avatar
its all about increased air flow. its just that cars went to v engine shape so later larger carbs are downdraft. increased air flow means increased max rpm
mike657894 is offline   Reply With Quote
Old 05-10-2016, 02:58 PM   #11
Tim Armstrong
Tim Armstrong's Avatar
I have seen a u shaped manifold adapter with a flathead six carb....worked great.
Tim Armstrong is offline   Reply With Quote
Old 05-10-2016, 03:37 PM   #12
Brian T
Brian T's Avatar
I got this at a swap meet last year, its a Holley #1907 50s Ford 6cyl, the only reason I did was because it was bolted to a very nice late 31 exhaust manifold the seller would not separate.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 05-10-2016, 03:42 PM   #13
COOTER
Suppose I could give it a try and see how it goes.
Old 05-10-2016, 04:12 PM   #14
Ron W
Ron W's Avatar
Watch out for puddling in the lower vertical section. Ron W
Ron W is offline   Reply With Quote
Old 05-10-2016, 06:50 PM   #15
Benson
Benson's Avatar
Vince,
So that manifold must be for use with the Detroit Lubricator carb or is this for some Russian GAZ carb?
Looks like maybe some Russian writing on the manifold.
Looks like a preheat pad on manifold so maybe for use in Siberia! Although the Model A has pre-heater pad also.
I tried an after market downdraft manifold without pre-heater pad and found it to be very cold blooded even in mild cold spells.
Benson is offline   Reply With Quote
Old 05-10-2016, 06:54 PM   #16
Juggler
Juggler's Avatar
German G28 I think
Juggler is offline   Reply With Quote
Old 05-10-2016, 11:08 PM   #17
Benson
Benson's Avatar
Vince,
Thanks for info.
I worked with the Solex carbs on VW Bugs starting with 1950's models and up to 1969 when the Type IIIs went to Fuel Injection.
The 68 Type IIIs were the last ones with twin Solex.
I had a 69 and a 73 Type III.
The Bugs, Buses and Karmen Ghias continued with single Solex carbs until early to mid 70's as I remember.
My '76 Dasher was CIS Continuous Injection System.
There were a couple guys in Denver that plugged up and inverted a Model A manifold like you mentioned above. This setup used a Ford Econoline Van carb with that same manifold configuration.
Old 07-01-2020, 11:28 AM   #18
Peter Braun
Peter Braun's Avatar
I run a Solex 32 PBIC on my G28 engine. These carbs were used by Citroen Traction Avant (11/15 CV) and early ID 19. Feels a little breathless in higher revs... but runs smoothly and is very responsive in lower revs
Cheers
Peter from Germany
Peter Braun is offline   Reply With Quote
