01-01-2020, 09:36 PM | #1 |
Pressure Test Plate Patterns/Drawings
Does anyone have the drawings or files for, say, a 59a style head gasket and water pump? I'm not wanting to make gaskets, I may have access to a water jet and would like to maybe have some pressure testing plates cut out. I don't have access to good drawing software any longer....
"Constipated, can't pass a thing! Don't laugh, bud, your daughter may be in here. They don't call 'em flyn' flatheads for nothin'!" Hot Rod (Kennie) Holmes |
01-01-2020, 10:12 PM | #2 |
Re: Pressure Test Plate Patterns/Drawings
Can you use a head gasket & water pump gasket for a pattern?
01-01-2020, 10:13 PM | #3 | |
1- Get some used or new gaskets for patterns. 2- Rub trace the areas to paper. Make sure the paper is fastened tight so it doesn't move during rubbing. 3- Try some of the free drawing programs available for download. I have not used this one but it looks like it might work. http://www.inkscape.org/en/ While you are machining the head plate you can install holes for installing dowel pins to locate heads. |
01-02-2020, 12:54 AM | #4 |
Pete, where is the best general location for the pins?
01-02-2020, 05:48 AM | #5 |
I've been using QCAD it seems pretty good.
01-02-2020, 06:33 AM | #6 |
We use our honing plate as the template to locate the holes. We drill the block holes with a letter "D" drill and the head and gasket holes .250". Began doing this procedure about 20 years or so back! Thanks, Gary in N.Y. P.S. Wishing all here a very Happy New Year!
http://www.stromberg-bulletin.com/me...berg-equipped/ |
01-02-2020, 12:22 PM | #7 |
