11-13-2021, 12:25 PM | #21 | |
Re: Positive Ground
Today you can buy a device from any of the suppliers that hooks to the coil and an LED will tell you if it is correct. I bought one years ago and at a club event we tested about 20 cars. About half were incorrect and the owners were not aware of it. Tom Endy |
11-13-2021, 01:06 PM | #22 | |
Re: Positive Ground
Just check it with analog voltmeter and reverse the primary coil wires if necessary. I think Jim Linder at Bubba's Ignition services or somebody said something about an ignition coil being permanently damaged by this defect, if ran for a long time, as the iron core is magnetized? Something like that. I like the neon or LED tester idea, should be easy to make one. |
11-13-2021, 01:16 PM | #23 |
Re: Positive Ground
I agree, if someone doesn't like the polarity they have, change it. There is too much polarity in the world now anyway.
11-13-2021, 03:59 PM | #24 |
Re: Positive Ground
Most lightening is produced when the ground is negative and the clouds positive, so the electrons travel up from the ground. Tell that to Thor next time he tosses down a thunder bolt.
The latest theory about everything is that matter is just forms of fragments of energy. These fragments are long strings that flow through the universe. The math behind this theory has shown to calculate gravity according to general relativity and how particles behave according to quantum mechanics.
11-14-2021, 09:55 AM | #25 |
Re: Positive Ground
Lightening is a form of static discharge energy which has it's own rules with energy levels high in the megajoules. It has no conductor but can make ion pathways that allow for the discharge to move any way it wants to. The potential energy is way off normal electrical scales.
A coil works with half wave DC current so it shouldn't have any effect on magnetization similar to AC current. With the power applied to a completed coil circuit, it will build a magnetic field in the core if it is connected either way but the pathway to the breaker points is important to get the most efficient reversal of the magnetic field when the circuit is broken. The reverse flow has to take a very long pathway to create a discharge of high energy. This link has a good coil diagram so you can see the normal pathway. https://mgaguru.com/mgtech/ignition/ig108.htm In the Magnaflux inspection procedures, DC current is used to magnetize steel parts for inspection. It takes a lot of amperage to magnetize a part. Coil shots give a lengthwise gauss field and straight through head shots give circular gauss field in a steel part. After magnetization, the steel parts are slowly passed through a big AC coil to demagnetize the parts. Complicated shapes sometimes take a few passes through the AC coil but it will remove all magnetism from the parts. AC has a full wave current flow with constant reversal of the polarity. DC can only be manipulated to half wave to make a polarity reversal as in ignition coil, horn vibrator, and radio vibrator circuits. Last edited by rotorwrench; 11-14-2021 at 10:04 AM. |
11-14-2021, 10:02 AM | #26 |
Re: Positive Ground
11-14-2021, 10:02 AM | #27 |
Re: Positive Ground
Smoke don't care! You let the smoke out, and the beast won't work. Keep the smoke in!
11-14-2021, 02:08 PM | #28 | |
Re: Positive Ground
11-14-2021, 07:29 PM | #29 |
Re: Positive Ground
rotorwrench, Doesn't the capacitor and coil set up a resonance ringing that causes multiple sparks at the spark plugs, in a really short time. The first spark is the big one, of course.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 11-15-2021 at 08:51 AM. |
11-15-2021, 09:50 AM | #30 |
Re: Positive Ground
The condenser catches the back flow from the reversal of the magnetic field when the points open and does have a bleed off that delays the complete induction process so it does keep the spark discharge going for a very short period of time. The scope illustrates that effect.
The condenser or capacitor is sized to match up with the resonance of the inductor coil so that the cycle will be as efficient as possible. The resonance is like the ring of a bell when struck. The back flow of energy would jump the open breaker points if the condenser was not in the circuit to catch it which would quickly ruin the points and reduce the spark discharge to near nothing. Last edited by rotorwrench; 11-15-2021 at 09:59 AM. |
11-15-2021, 11:28 AM | #31 |
Re: Positive Ground
The way it was explained to me years ago, the condenser acts as a kind of "shock absorber" and ensures most of the energy occurs between the plug electrodes where we want it, instead of arcing at the points.
I've seen in some of the forums people say they've been able to run a motor without a condenser installed for whatever reason. I don't think they are lying, so I wonder how that works. Theoretically it shouldn't run at all without a condenser? I'm sure it didn't run very well. |
11-15-2021, 12:37 PM | #32 |
Re: Positive Ground
Boy there is a lot of interesting explanations here.
One of the reasons for using negative ground is corrosion. Many people use electrolysis to remove rust from iron or steel parts. The part is connected to the negative wire and a sacrifice piece of iron is connected to the positive wire. Rust is removed from the part connected to the negative wire and the sacrifice piece becomes rusty. A positive ground vehicle will rust much faster than a negative ground one. I did my Master Thesis on proton conductivity. This is a rare phenomenon. It only occurs is certain crystals with loosely held protons. By definition protons have a positive charge. They do not transfer their charge. We use the term electricity because it is the movement of electrons. The electrons move from the negative source to the positive. Bob |
11-15-2021, 04:56 PM | #33 |
Positive Ground
11-15-2021, 11:43 PM | #34 |
Re: Positive Ground
This question has been asked for a long time.
Here is an article on it from the August of 1931 Automobile Digest.
Bill Cilker, Jr Unrestored 190A Victoria 45B, 160B & 189A Victoria Association President |
11-16-2021, 04:35 AM | #35 | |
Re: Positive Ground
But it does make sense when you think about it... in a corrosion process, the metal will pass its electrons to the oxyidiser, which will gladly accept it. If you have a negative ground system, the metal will find an abundance of electrons and therefore cannot pass its electrons to 'whoever'. But i agree that this effect may be miniscule... |
11-16-2021, 06:44 AM | #36 |
Re: Positive Ground
Bill, good research. Thanks. I guess this is a good argument for using electrical grease to protect the cables and connectors. I see the auto parts stores have different grease and pads for the negative and positive sides of the battery.
