07-25-2021, 06:32 PM | #21 |
Re: Zenith - 1 Carburetor
What is the GAV and where is it located? Thank you. David… by reading the posts I am thinking it’s the fuel adjusting needle in the choke driver as in the manual. If I’m wrong someone please let me know.
07-25-2021, 07:34 PM | #22 |
Honness, You are correct. GAV stands for Gas Adjustment Valve.
07-25-2021, 07:40 PM | #23 | |
I'm not sure what carburetor the instructions are for in post #1. As far as I know there is no "packing nut" on the GAV
Ruth "Sometimes you really DO need to read the whole thread" Last edited by Ruth; 07-25-2021 at 07:52 PM. |
07-26-2021, 09:52 AM | #24 |
[QUOTE=Ruth;2039547]To add to your list, Throttle shaft/carb body worn and sucking air in. I find this most common on old carburetors. Oversize shafts and bushings are available.
I believe I might have updated this thread awhile back, but sorry if I did not. I found that the main jet was undersized, and opened it up with a #63 jet drill bit. It now works and runs perfectly @ 1/8 turn open of the GAV. Thanks for all the help.
IN GOD WE TRUST - SEMPER FIDELIS John |
