Old 11-01-2020, 03:46 PM   #1
jack99
Default Radiator Syphon
I have a 1935 Ford with the 221 engine. What causes the radiator to syphon to the overflow tube when the engine reaches normal temperature?
Any thoughts? Thanks
jack99 is offline   Reply With Quote
Old 11-01-2020, 04:39 PM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: Radiator Syphon
If you over fill it will flow out until it finds it comfortable high 2" downs about right ,if it goes lower you have a problem Gasket or blocked core ,Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 11-01-2020, 07:02 PM   #3
JWL
Ted hit the most obvious problem--if the coolant cannot pass through the cores with adequate flow rates the top tank will fill and actually become slightly pressurized and coolant will be expelled out the overflow.
JWL is offline   Reply With Quote
Old 11-01-2020, 10:22 PM   #4
G.M.
This happens as the engine cools. As the temp drops threw
155 degrees there is a vacume in the engine and the coolant
is sucked from the coolant overflow bottle back into the
radiator. You need a 2 to 4 lb pressure cap and an overflow
bottle for this to work. G.M.
www.fordcollector.com
