Old 01-07-2020, 09:41 AM   #1
gwmartin55
Default E3 plugs
Has anyone successfully used the E3 spark plugs. 37 21 stud, scat crank.
gwmartin55 is offline   Reply With Quote
Old 01-07-2020, 09:51 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: E3 plugs
Been using them on an 8CM Merc. for a couple of years.
Noticeable difference in starting. Run well but can't document any measurable effects.
The E3-10's I am using have about 1/16" shorter reach than stock H-10's but the tip protrusion in the chamber is virtually identical.
Old 01-08-2020, 06:02 AM   #3
flatmotor40
flatmotor40's Avatar
What about with Offy heads
flatmotor40 is offline   Reply With Quote
Old 01-08-2020, 09:11 AM   #4
51 MERC-CT
51 MERC-CT's Avatar
You would have to do a search to see what is available in your 'reach' requirements.
Using your current plug Mfg. and part number you may be able to see by using E-3's cross reference page if an equivalent is available.
Old 01-09-2020, 06:12 AM   #5
flatmotor40
Thanks
Old 01-09-2020, 11:40 AM   #6
1948F-1Pickup
1948F-1Pickup's Avatar
I can't recall where I saw the test but the E3 plug was the only electrode design
that showed ANY improvements in horsepower and mileage. May have been Hot Rod or Car Craft or some such deal. The testers "apples to apples" evaluated 5-6 different manufacturers and were surprised because the spark plug category is generally a good one to see lots of snake oil.
1948F-1Pickup is offline   Reply With Quote
Old 01-09-2020, 11:05 PM   #7
gwmartin55
Thanks so much.
