08-09-2019, 03:54 PM | #1 |
Long Shot on tractors
Might anyone know the cylinder pressure norms for an Intl M Tractor ? Having starting problems and I believe we need new rings. ??
08-09-2019, 06:13 PM | #2 |
Re: Long Shot on tractors
go to yesterdays tractors forum click on farmall
08-10-2019, 12:36 AM | #3 | |
If you have the hand crank, use it to turn the engine over with the switch off. If the rings are bad, you will hear a lot of hissing and not much compression resistance. |
08-10-2019, 09:27 AM | #4 |
If you crank it with the spark plugs out, it should blow your finger off each one of the spark plug holes. If it can't do that then it needs more work. Check for spark from any of the plugs grounded against the block. If it has fuel, spark, and compression it should start. |
Thread Tools | |
Display Modes | |
