08-21-2020, 09:49 PM | #1 |
RPm on open road
What is preferred rpm when on open road? Fresh 37, 21 stud engine 3:55 gears . Choice of tires open. Shift at 25 and 38 mph. Expect lots of open road driving. Don’t want to over rev it on long trips.
08-21-2020, 10:02 PM | #2 |
Re: RPm on open road
It is somewhat a matter of personal preference. 2500 isn't a bad starting point.
08-21-2020, 10:14 PM | #3 |
Do you have a tach?
08-22-2020, 03:44 AM | #4 |
Here is a calculator to give you an idea where you are with your car RPM.
600-16 bias tires are about 28-28.5” tall. With 3.55 gears you will turn abt. 2350 @ 55, your engine should be happy. The Columbia chart gives a close comparison too. http://www.csgnetwork.com/multirpmcalc.html
Tim Downtown, Ca Last edited by CA Victoria; 08-22-2020 at 04:05 AM. |
08-22-2020, 05:28 AM | #5 |
08-22-2020, 06:56 AM | #6 |
08-22-2020, 08:41 AM | #7 |
I think it is easier to just run the numbers.
RPM = (Axle Ratio x MPH x 336) ÷ (Tire Dia) Last edited by JSeery; 08-22-2020 at 09:38 AM. |
