04-29-2020, 09:58 PM | #1 |
Wiring in Turn signals ?
I have a used 6 volt basic turn signal set up for an old car/ truck that mounts on the steering column.I want to mount into a 35 pickup Might anyone have a wiring diagram ?
04-29-2020, 10:03 PM | #2 |
Re: Wiring in Turn signals ?
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 04-29-2020 at 10:20 PM. |
04-29-2020, 10:25 PM | #3 |
nice post put up by pete, but if you have an older model they are set up to have a separate bulb for each circuit. i just did an old one, a signalstat model 700, it needs relays to function on your existing single bulb tail lights, so what model of switch do you have?
04-29-2020, 11:34 PM | #4 |
There are several different units. The wire count coming out of the switch unit will ID the bulb arrangement I think. Then there is the wire color coding.
04-30-2020, 01:31 AM | #5 |
Make sure your turn signal bulbs are large enough to operate the relay
04-30-2020, 05:54 AM | #6 |
trailers have 4 rear lights in which any signal switch will work (no need for the stop light switch) 2 rear lights then you need to tie into the stop light switch as diagrams above....The signal switch doesn't care 6 12 or 24 volts ITS the flasher voltage... |
04-30-2020, 02:12 PM | #7 |
Unless your truck has been rewired; it has only one brake light wire serving one or two rear lights and single contact sockets up front for the park lights.
While there is nothing wrong with the previous replies It would be useful to have both the wire count on the signal switch and a run down on your existing truck wiring to furnish advice accurate to your situation. Last edited by rich b; 04-30-2020 at 09:27 PM. Reason: extra |
04-30-2020, 03:32 PM | #8 |
On my '48 F-1 I had to replace the parking light bulb sockets with double filament bulb sockets, The after market sockets were a little smaller so I built up solder on them to make them fit tight.
05-02-2020, 03:08 PM | #9 |
Thanks, all. Good info. I should have enough to go on . I believe this is enough to figure it out now
