Old 09-28-2017, 08:36 AM   #1
jack99
Default 160B Town Sedan rear fender
Could someone please describe the difference in design of the correct fender for a 1931 Town sedan (slant Window). I know there I a "dimple" for a rivet or bolt. I am going to Hershey in search of one. What would be fair value for such a fender? If you have a photo it would also help.
Thanks so much.
jack99 is offline   Reply With Quote
Old 09-28-2017, 05:59 PM   #2
J Franklin
J Franklin's Avatar
Default Re: 160B Town Sedan rear fender
Do you have access to a copy of the judging standards? I thought all the '30-'31 sedan fenders were the same
Old 09-28-2017, 06:53 PM   #3
1930artdeco
1930artdeco's Avatar
Are you looking for front or rear? I have a spare left rear if you want it.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 09-29-2017, 08:19 AM   #4
Oldbluoval
Oldbluoval's Avatar
I make those and have a template as to where it goes. Don't make lack of that dimple be a factor; easy fix. If you are building a true show car then you need to look for mfg markings, etc., also.
[email protected]
Old 09-29-2017, 11:18 AM   #5
160B
160B's Avatar
RG&JS Page 13-9 Revised 2016
• Beginning in March 1931, all sedan fenders had a dimple
stamped into the inside rear skirt. The dimple was added
to provide clearance for a body rivet on the 160 series
sedans.
see attached file
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
