11-30-2021, 09:31 PM | #1 |
60HP vs 85HP generator and coil
Do 60 & 85HP engines use the same generator and coil?
11-30-2021, 10:09 PM | #2 |
Re: 60HP vs 85HP generator and coil
Lawson, the 1937 parts book shows the coils are the same between the two size engines and the generators are different part numbers.
11-30-2021, 10:50 PM | #3 |
[QUOTE=Zeke3;2081013]Lawson, the 1937 parts book shows the coils are the same between the two size engines and the generators are different part numbers.
Thanks Zeke3. Now I'm on the hunt for a 60HP generator. I would assume the fans are the same but maybe someone will chime in here on that query.
12-01-2021, 01:09 AM | #4 |
Interesting question. No expert here, but I would assume the basic electrics of the car having the 60 are the same as an 85, so why would Henry have a different part? I have some 60 stuff here, I'll check that the manifold mount is the same
12-01-2021, 02:40 AM | #5 |
On my coupe, the fan has an extension to bring up to the radiator cos the block is several inches shorter than an 85
12-01-2021, 05:03 AM | #6 |
12-01-2021, 06:39 AM | #7 |
I believe the gen housing is the same as a 85, the pulley is a smaller diameter and the 60 fan does have an extension on it. I am pretty sure I have a 85 gen on the 69 in my 39.
12-01-2021, 07:32 AM | #8 |
Jim. Glad you chimed in. Could you shoot me a picture of your generator, from the side, showing the fan hub, and give me the diameter of the pulley. I may have a pulley and fan amongst my stash that will work. If the housings are the same Jeff Smith (Putt's son) still has all of Putts stuff and hopefully I can get one locally and save shipping. I'll try to call you around Noon today, 12/1/21. You are on Eastern time, right?
12-01-2021, 11:01 AM | #9 | |
Here Lawson is a side view pic of the V8 60 |
12-01-2021, 02:23 PM | #10 |
Thanks duce lover. Is that, or another 60HP available so you can measure the length of the hub on that fan where I can see if the one I have is correct for the 60HP I have finally acquired? Thanks again Lawson
12-01-2021, 04:15 PM | #11 |
I pulled the pic off the EBAY listing.
12-01-2021, 04:44 PM | #12 |
Thanks. I'll email the seller and ask him to measure the hub for me.
12-02-2021, 02:42 AM | #13 | |
Here is the link. https://www.ebay.com/itm/17493214594...UAAOSwjw5hOrVh |
