Old 10-31-2021, 10:17 AM   #1
rust revival
Default Bushings and reamers ***thread to end all threads*** add your knowledge
Did a little search and came up short,
Does anyone know reamer size for
1935-48 Ford transmission clutch shaft bushings--------
1932-48 Ford distributor housing shaft bushing---------
1932-48 Ford flathead fuel pump push rod bushing------ 1932-48 Ford 48-52 steering sector shaft bushings--------
1932 1933 1934 Ford clutch / brake pedal bushings---
I see Master ford specialty reamer (wooden box) sets pop up from time to time but not sure if the are pre 28
Any detailed help would be appreciated greatly, for me and others to come
rust revival is offline   Reply With Quote
Old 10-31-2021, 10:29 AM   #2
sugarmaker
sugarmaker's Avatar
Default Re: Bushings and reamers ***thread to end all threads*** add your knowledge
RR,
I will only guess at the distributor and may be way off but the 32 that we just did was good at .501 inch.
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
2015 Ford F250 SuperCrew
Lots of Allis tractors
Some Cub Cadets
Old 11-01-2021, 06:22 AM   #3
Mac VP
Mac VP's Avatar
If you want a close to perfect fit on the clutch shaft bushings, I would get an adjustable reamer. I’d have to check to see what size we bought for the shop but the reality is that there are subtle differences in the bushings AND the clutch release shafts. The fine adjustments you can make with the adjustable reamer will compensate for these. If you don’t want to spend the money for that tool because you’re only doing this job once, just use a regular brake wheel cylinder hone. It’s probably going to take longer but it’s much less expensive.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 11-01-2021, 12:03 PM   #4
Brian
Brian's Avatar
I've held off posting on this thread, but, further to what Mac said, 1932-48 Ford distributor housing shaft bushing is an oilite bush...you DO NOT ream oilite bushes, reaming these things will smear the surface, they need to maintain their built in oil holding capabilities.
1932-48 Ford flathead fuel pump push rod bushing; originally these were heat treated steel, modern replacements are bronze, however, these things are such a rattling fit on the pushrod, you'll not need to open them up any more...
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 11-01-2021, 01:40 PM   #5
Zeke3
Zeke3's Avatar
For the clutch cross shaft, I used a brake wheel cylinder hone as Mac suggested above. It did not take very long to get a satisfactory fit on my trans housing.
Zeke3 is offline   Reply With Quote
Old 11-03-2021, 02:58 PM   #6
rust revival
Thank you fellas this, is all very good information
Old 11-04-2021, 08:14 AM   #7
Frank Miller
Frank Miller's Avatar
My friend had reproduction brake actuators levers for his 34 and they were two different sizes. Not that you would notice but a thousandth or two makes a difference when you want a good fit.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 11-04-2021, 11:08 AM   #8
RalphM
RalphM's Avatar
King pin and bushing reamer, adjustable from 25/32 to 27/32 to use a .812 king pin.
Second is the steering gearbox bushing reamer , 1 1/4 inch.
I have another one somewhere for doing the carburetor shaft bushing’s.
File Type: jpeg 578150FB-2408-4B53-B312-2880E4777EF3.jpeg (115.7 KB, 31 views)
RalphM is offline   Reply With Quote
