03-05-2014, 08:43 PM | #1 |
32-35 babbit main crank
I just stripped a 35 engine with a junk block. I was thinking, and that always gets me in trouble. Question, what's the difference between a 32 to 35 crank? I know they all have 2in. main and 2in. rod journals. Will they all interchange? Thanks Walt
03-05-2014, 09:20 PM | #2 |
Re: 32-35 babbit main crank
Walt, I know they use the same rod bearings and have the rabbit mains,crank pulley is the same,
I have both and they look the same, I will look at the part number. Lawrie |
03-05-2014, 10:06 PM | #3 |
in the parts book it lists as 32-36 2" journals
03-06-2014, 08:53 AM | #4 |
Walt, I have a complete block I am going to sell if you need one. Has crank and pistons and valves etc. I am not going to use it and my son found an L.B. he is going to use instead. Kerk
03-07-2014, 10:03 AM | #5 |
same crank was used as a replacement back to 1932. Some 1932 cranks were steel.
03-07-2014, 11:40 AM | #6 |
03-07-2014, 12:20 PM | #7 | |
1937 & 1938 21 stud used the same crank & the 81a 1938 24 stud engine used same crank--short nose , small main 2.4 ", small bore flush face pulley. Please let me know if this is incorrect--@ 72 + , I'm still learning. Gene Tulsa Last edited by G32; 03-07-2014 at 01:28 PM. Reason: Finish sentence |
03-07-2014, 06:54 PM | #8 |
Wasn't the '32' Crank a Forging, and the others castings.
03-07-2014, 07:58 PM | #9 |
I knew the 36LB and 37-38 21stud had the same crank 2.400 main BUT I didn't relize the 38 24stud used that same crank. I thought when they went to 24stud they went 2.500 crank. No matter how long you work on flatheads every once in awhile you learn something new. I think I'll start using cross word puzzels. That would keep me busy a long time on the first page. Walt
