Old 09-18-2022, 09:25 PM   #1
J Franklin
J Franklin's Avatar
Default Quieting a model T
What can or has been done to make a model T run more quietly? I have a new pipe and muffler and it is quite noisy.
Old 09-19-2022, 04:48 AM   #2
A bones
A bones's Avatar
Default Re: Quieting a model T
If you speak of noisy exhaust, who's muffler are you using?
I knew a fellow that sourced a muffler for an early Falcon. It worked out okay.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 09-19-2022, 05:07 PM   #3
J Franklin
J Franklin's Avatar
It is the exhaust that seems noisy. I just have a muffler that the T shops sell. I might be able to find a different one, Falcon will be on the list. Any other ideas anyone?
Old 09-19-2022, 05:19 PM   #4
39portlander
39portlander's Avatar
J. F. I wish you were closer would love to help, but...I'm thinking you have something loose vibrating against something else when running.
I'm a big fan on the 3063MC manifold kit langs sells for the intake/exhaust ports, start there and work your way back.
Let us know how you make out with there.
I will add I had an infrequent noise earlier this season and found my hand crank spring worn out and allowing the hand crank to slowly move inward and the crank and handle ends started touching each other.
39portlander is offline   Reply With Quote
