Old 07-22-2019, 04:42 PM   #21
Bob C
Default Re: Hole in water jacket
Did you break into the water jacket on the side??
Bob
Old 07-24-2019, 05:33 AM   #22
mill48
mill48's Avatar
Yes, I drilled too far and punctured it on the side where the intake manifold is.
mill48 is offline   Reply With Quote
Old 07-25-2019, 08:06 AM   #23
George Miller
George Miller's Avatar
Are you saying you did not drill the stud in the center?
George Miller is offline   Reply With Quote
Old 07-25-2019, 10:14 AM   #24
Benson
Benson's Avatar
delete duplicate
Benson is offline   Reply With Quote
Old 07-25-2019, 10:17 AM   #25
Benson
Benson's Avatar
Here is what is behind the manifold stud hole in block.
Since hole is off center best get someone to install cast iron plug and use milling machine to relocate the hole for stud.
This is another reason to measure depth of hole before drilling.
There is very little "wiggle room" here.
The best way to remove broken studs is to weld a washer to stud then weld nut on the washer like mentioned on Vince Falter's website or use milling machine.
Impact wrench to remove studs is a very bad idea also unless done properly.
Old 07-26-2019, 04:08 AM   #26
SAJ
SAJ's Avatar
Fantastic picture Benson. I am saving that one in case I ever come across a leak or problem with these studs.
SAJ in NZ
SAJ is offline   Reply With Quote
Old 07-27-2019, 08:01 AM   #27
Benson
Benson's Avatar
SAJ in NZ
Hope it helps someone...
Yes ... kinda nice to know what is "going on" inside the casting!
Ain't so?
Old 07-28-2019, 09:12 AM   #28
James Rogers
James Rogers's Avatar
Permatex #2. It does not get hard and will stop the seepage. I find many blocks that have the head studs drilled or rusted into the water jacket and this works unbelievably well. Does not harden to the point that the stud can not be removed.
