02-09-2018, 11:00 PM | #1 |
Source for 6v turn signal flasher
All,
I recently installed turn signals on the 41. I'm running 6v positive earth. I used a 6v motorcycle flasher can and now it is flashing erratically when working. This makes me think I'm using the wrong type of flasher. What say you, and where can I source a correct replacement? Thanks in advance for your assistance |
02-09-2018, 11:23 PM | #2 |
Re: Source for 6v turn signal flasher
02-09-2018, 11:25 PM | #3 |
you need a 6v 3 prong flasher. I got mine from Macs (now Ecklers) C&G or any of the v8 parts store will have them. I imagine your local auto sparky might even have them or auto electrical outlet. If you installed LEDS you need a special 6v flasher... you can't use the normal "tin can" type. Check your earth too. Most of those aftermarket turn signal switches are earthed through the clamp to the steering column. It usually means scraping some paint off it. It may be just a crook earth.
GB 7
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" Last edited by Graeme / New Zealand; 02-10-2018 at 12:31 AM. |
02-10-2018, 01:53 AM | #4 |
Many thanks gents,
I checked the earth on the flasher I have (it's a separate lead), and no luck... I have ordered some replacements. |
02-10-2018, 09:55 AM | #5 |
NAPA carries them #NF535
02-10-2018, 02:20 PM | #6 |
02-10-2018, 06:22 PM | #7 |
The flasher is very erratic. It flashes at a regular cadence, then goes into disco mode for a bit, then remembers where it is and settles down.
02-10-2018, 08:47 PM | #8 |
Maybe it's a safety feature!
