Old 12-26-2022, 05:55 PM   #1
harryc
Default sediment bowl removal ideas
nut on cast iron sediment bowl is rusted solid. any simple ideas for removal. I am not going to try heating with a torch
harryc is offline   Reply With Quote
Old 12-26-2022, 07:11 PM   #2
stevests
stevests's Avatar
Default Re: sediment bowl removal ideas
What nut ? The screen access port ?
stevests is offline   Reply With Quote
Old 12-27-2022, 10:29 AM   #3
rotorwrench
rotorwrench's Avatar
Dissimilar metals can get some corrosion build between the lower cap if it's brass and the sediment bowl (cast iron). If both are cast iron then disregard. It will need several heating and cooling cycles to free it up. It doesn't take much more than the temperature of boiling water to free things up sometimes. Put it in a sauce pan with water and bring it to a boil then let it cool down. It may take several times to free it up. Carefully take the hot assembly and put it in the freezer to further shock the threaded fit up. Expansion and contraction will free most things up. I use the torch on bolts and non fuel related fasteners but some just have to be cut off if the corrosion is extensive. A person can use heat on fuel related parts but all traces of the fuel have to be removed before heating or welding on a fuel related assembly.
The late type sediment bowls also have a packing nut for the valve. Is this an early type or a late type sediment bowl? There is a difference in the size and placement of the screen caps.
This is a good link.
https://www.mtfca.com/model_t_encycl...ediment-bowls/
Old 12-27-2022, 06:45 PM   #4
harryc
the problem is it's still attached to the firewall-----not much accessibility under the gas tank
Old 12-27-2022, 06:59 PM   #5
harryc
sorry wrong thread !!
Old 12-27-2022, 09:03 PM   #6
redmodelt
redmodelt's Avatar
Oh Model A! Happens. Try and find a socket or box wrench that will grab at all the corners and give that a try after soaking with Kroll or other real penetrating oil. Might also use a brass wire brush to clean the thread some first.
Old 12-28-2022, 07:27 AM   #7
Robert/Texas
Robert/Texas's Avatar
I'm a believer in using a mixture of 50/50 acetone and ATF for these kind of problems. This has always works better for me than the stuff that comes in the squirt cans.
Robert/Texas is offline   Reply With Quote
Old 01-02-2023, 09:54 AM   #8
39portlander
39portlander's Avatar
induction innovations mini-ductor, purge with nitrogen while heating up the nut and surrounding area.
39portlander is offline   Reply With Quote
