06-02-2023, 05:24 AM | #1 |
New vinyl top insert fits loose
Over the winter I put a new top insert in my coupe. It fit nice when I did it in April, but now that it's gotten warmer it's loose in the middle. My friends told me vinyl will shrink, leave it in the sun, ect, but leaving it in the sun almost makes it worse. I chased it around with a heat gun, it seems like that just moved the looseness to the edge. I'm thinking of unstapling the edge and tucking it tighter but I don't want to ruin the new edging material. Is there something else I can do to make it fit better?
06-02-2023, 05:49 AM | #2 |
Re: New vinyl top insert fits loose
I have seen similar results when shops install convertible tops. They loosen up, wrinkle and dont look so good. Imperative to get it tight from the beginning. also may have to do with the pad used in the top. Should be cotton and not a variation of plastic, that will decay over time. |
