11-15-2017, 06:16 PM | #41 |
Re: SO incredibly mad at myself!!!
When I was a heavy mechanic we put switches on every machine that used oil pressure that work great we just use the small oil pressure switch and then went to a constant on solenoid which operated everything but the starter. As soon as the oil pressure hit we had ignition in lights
Sent from my SM-J700T using Tapatalk |
11-15-2017, 10:12 PM | #42 |
Mr Hoovie is politically correct, I put a connector in the wire to the coil. I dont know which is worse forgetting to unplug the wire or forgetting to plug it back together after working on it. I keep forgetting to remember what i forgot.
11-15-2017, 11:17 PM | #43 |
So you're saying you run down your battery trying to start it the next day because you forgot to reconnect it? I feel right at home here. So many great suggestions. I'm picturing a battery switch that looks like new. I took it off an 8n ford tractor 20 years ago. It has a key in it to activate it. I think I saw it about 5 years ago in a box in the attic over the cabinet shop. I'll do some digging this weekend. I know it's up there somewhere......
11-16-2017, 12:12 AM | #44 |
Only thing to do is let it all cool off and see what happens - might be just fine.
11-16-2017, 03:09 AM | #45 |
I damaged a coil on a Buick many years ago by leaving the ignition on. It recovered, but was never right and deteriorated until it needed a new coil. The coil plastic had actually cracked and the oil had leaked out, causing it to overheat after running for a while.
So, if it seems ok, I'd advise to carry a spare "get you home" coil until you have run it long enough and far enough to make sure all is well. Mart. |
11-20-2017, 12:04 AM | #46 |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) Last edited by GB SISSON; 11-20-2017 at 12:25 AM. |
11-20-2017, 09:23 AM | #47 |
carguybill got a part number and source for the breaker you use?
