06-27-2013, 04:03 PM | #1 |
wiring harness
I'm going to re-wire my car...any recommendations on a good company to buy the harness from?
06-27-2013, 04:17 PM | #2 |
Re: wiring harness
Tyree Harris or Sacramento Vintage Ford. Both of these manufacture a very nice harness.
06-27-2013, 05:08 PM | #3 |
Re: wiring harness
Sacramento Vintage Ford is my choice.
06-27-2013, 05:30 PM | #4 |
Re: wiring harness
Tyree Harris. 804-833-5200 [email protected]
http://www.narragansettreproductions...parts-ford.pdf also has harnesses and covers their own wire.
06-27-2013, 05:35 PM | #5 |
Re: wiring harness
i orderwd mine for 30 town sedan from macs and it fit and worked perfectly.
fred |
06-27-2013, 07:25 PM | #6 |
Re: wiring harness
06-27-2013, 07:37 PM | #7 |
Re: wiring harness
06-27-2013, 09:58 PM | #8 |
Re: wiring harness
06-28-2013, 01:09 PM | #9 |
Re: wiring harness
so i need a main harness and what else? i do NOT have cowl lights
06-28-2013, 01:36 PM | #10 |
Re: wiring harness
I got mine from Bratton's: for a 1930 Canadian Roadster: includes cowl lights and turn signals. Easy install: works well.
06-28-2013, 01:51 PM | #11 |
Re: wiring harness
I would think that if you called a vendor and said "I need all the harnesses for a Model A with single/dual tail lights, with/without cowl lights, with/without turn signals, they could pull what you need.
06-28-2013, 04:09 PM | #12 | |
Re: wiring harness
1. Main light harness (includes headlamp and taillight) 2. Generator to terminal box harness 3. Instrument panel harness 4. Coil feed wire to terminal box 5. Battery cables 6. Popout cable 7. Distributor lower plate flex wire 8. Ignition coil wire 9 Spark plug leads That's all the wiring that comes to mind, but you are probably only looking at the first 4 when you think of wiring harness to rewire the car. |
06-29-2013, 08:25 AM | #13 |
Re: wiring harness
Thank you for all the help guys.
