Old 07-20-2019, 07:52 AM   #1
old31
Default New type of motor mounts what do you think?
Has anyone tried these motor mounts and if so what are your thoughts?
https://www.snydersantiqueauto.com/P...earchByKeyword
Old 07-20-2019, 08:08 AM   #2
Mulletwagon
Mulletwagon's Avatar
Default Re: New type of motor mounts what do you think?
Probably works - but a little bit of vibration in the passenger compartment is part of the Model A experience. Not sure the benefit is worth the cost and effort or originality compromise. Welcome feedback from someone that tried it.
Mulletwagon is offline   Reply With Quote
Old 07-20-2019, 10:46 AM   #3
Y-Blockhead
Y-Blockhead's Avatar
I think Float-a-Motor mounts can hardly be called "New" as they have been around for more than a few years.
That said, I have never tried the front mount. The stock front mount seems to work fine. And I refrain from drilling holes.
My car came with the rear mounts and I haven't seen the need to remove them. I have replaced the rubber "biscuits" a few times over the years.
Old 07-20-2019, 10:49 AM   #4
whirnot
whirnot's Avatar
Not exactly new. Most I have talked to don't use the front Float a motor, but do the back. My pickup had the back ones on when I bought it, and it is noticably smoother. I like them.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 07-20-2019, 04:38 PM   #5
john in illinois
john in illinois's Avatar
I use the FOM rear and stock front. Do not see a reason to change.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 07-20-2019, 04:55 PM   #6
woofa.express
woofa.express's Avatar
I changed to FAM rear mounts only and the vibration stopped. So did the tingling feeling in my hands.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 07-20-2019, 07:05 PM   #7
jw hash
jw hash's Avatar
not new at all. I have that mount a long with the float a motor in the rear. and when I get off my a`s I will do away with them both. some people like them I for one do not.
I broke my gas line three times from to much movement, and I was lucky that all three times it did not catch fire. now I have a breaded stainless flex line from the valve the Carb,
jw hash is online now   Reply With Quote
Old 07-21-2019, 11:44 AM   #8
PC/SR
I cut mine into 2 pieces. Don't know if it reduced vibration, but just seemed to be more sturdy than stock.
PC/SR is offline   Reply With Quote
Old 07-22-2019, 08:13 PM   #9
ericr
ericr's Avatar
just out of curiosity, does anyone briefly know how suspension changed in the '32 "B' and V-8 models, though I know the frame was entirely different.
ericr is offline   Reply With Quote
