Old 07-01-2019, 09:17 PM   #1
1965 Mustang
Default Two Electrical Questions
Actually one electrical question
Has anybody noticed that modern 12volt LED tests lights don't work so well when used on 6 volt systems? I tried a couple on my 6 volt cars and about half the time they don't light up at all and when I switch to an older incandescent test light they light up like they should.
1965 Mustang is offline   Reply With Quote
Old 07-01-2019, 09:19 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Two Electrical Questions
I'd say weaker Model A Battery until you charged it.
www.whidbeymodelaclub.com
Gary WA is online now   Reply With Quote
Old 07-01-2019, 09:37 PM   #3
jm29henry
jm29henry's Avatar
12 volt led on a 6 volt system may work poorly ! they were made for 12 volt with the lower voltage you would only get half the brightness or not work at all ,also if they did work the would probably burn out quicker. my suggestion is buy the proper 6 volt led lamp
and they should work great best of luck to you joe.
jm29henry is offline   Reply With Quote
Old 07-02-2019, 08:23 PM   #4
eagle
eagle's Avatar
Most LED bulbs are polarity sensitive. Use a voltmeter, much more valuable info in a voltage reading than just a "it lights".
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 07-02-2019, 10:11 PM   #5
mike657894
mike657894's Avatar
I also advocate multi meters. you can use the continuity setting to check grounds. also check connections and ohm out some parts. you can also runs some tests on batteries by how much voltage they have or how it drops as days go by.
mike657894 is offline   Reply With Quote
Old 07-04-2019, 09:33 AM   #6
Jerry in Shasta
Jerry in Shasta's Avatar
They may be below the diode's cut off voltage,they all very a little.
jb
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
