04-01-2019, 03:26 AM | #1 |
V-belt and very small pulleye
Hello at all, I have a question about the V-belt.
I'm currently building in Brattons alternator. The type, almost looks like the original one. The pulley has a very small diameter. There are V-belts that have teeth down inside. They are better suited for a very narrow radius. Has someone installed it and drives it well? Thank you for advice in advance.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
04-01-2019, 09:50 AM | #2 |
Re: V-belt and very small pulleye
Werner;
I know a number of people that use that style belt with the alternator. Yes it works fine. You are correct about the smaller pulley not working well with the original style belt.
04-01-2019, 04:32 PM | #3 |
Go with the castellated belt, I tried the original style belt when I went with the alternator and they kept braking. I think that the pulley diameter is too small for the original belt. The castellated belt is more flexible and has a better grip so it does not need to be very tight thus saving the water pump bearing.
04-01-2019, 06:46 PM | #4 | |
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
04-01-2019, 10:21 PM | #5 |
