Old 02-11-2018, 01:22 PM   #1
ungerp
Default 1930 5 Window
I just purchases an all metal 1930 Model A 5 window. I would like to put a small block ford engine and transmission in it with a 9 inch ford rearend. It appears that I will need at least a 4" if not 5" recessed firewall to accommodate this. Looking for advice on these topics from anyone who has done something similar already. Thanks, Pat
ungerp is offline   Reply With Quote
Old 02-11-2018, 01:26 PM   #2
Mikeinnj
Mikeinnj's Avatar
Default Re: 1930 5 Window
Pat, you will find an answer on the Jalopy Journal website here:
https://www.jalopyjournal.com
Mikeinnj is offline   Reply With Quote
Old 02-11-2018, 04:44 PM   #3
Dodge
Yes, look on the HAMB but you don’t have to indent the fire wall. Get a late Model explorer motor for the swap. Or at least the front drive and water pump. It shortens the motor by about 5 inches.
Dodge is offline   Reply With Quote
Old 02-11-2018, 04:52 PM   #4
workingclass42
Reverse your firewall
workingclass42 is offline   Reply With Quote
Old 02-12-2018, 09:50 AM   #5
V4F
V4F's Avatar
you don't need the 9" , the 8" works very well with no changes
V4f
V4F is offline   Reply With Quote
