06-07-2010, 02:13 PM | #1 |
Moto Meter won't fit new Radiator ?
I just installed a new Brassworks Radiator 10 fins per in the Model A and tried to install the Moto Meter and it will not fit ? any advice on the fix. What needs to be trimed or cut. Thanks for you replys.
06-07-2010, 02:17 PM | #2 |
Re: Moto Meter won't fit new Radiator ?
CALL THEM, before you trim and void any warranty, it is suppose to fit?
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
06-07-2010, 11:51 PM | #3 |
AGREED, call them. For the money they get it should work perfectly!!!
06-08-2010, 12:54 AM | #4 |
I recently tried to put a locking cap quail on a new radiator from Brattons. It did not fit . The I.D of the neck is smaller than the O.D of the cap. I had to trim the bosses that hold the brass tabs so it would slip past the top of the neck where the gasket seats.I had to grind the outside edge of each tab boss about .040.
06-08-2010, 12:55 AM | #5 |
Does your Motometer have adjustable tabs to secure it to the radiator neck and the meter rotates to flip back for access to the radiator neck.
Check for the tabs and loosen with the allen wrench, position the cap and meter correctly, tighten the tabs. If this is not the solution, let me emphasize the previous responses - Don't cut, file, or change anything without talking to Brassworks. They make a quality product and I'm sure the answer is elsewhere. Hope this helps, Steve |
06-08-2010, 06:09 AM | #6 |
06-08-2010, 06:14 AM | #7 |
Now that you mentioned this, I do remember doing something with a quail or motometer. I think there was instructions that came with the moto- meter for just this problem. I would definitely not modifier the radiator neck or tabs. Old age must be setting in just can't remember! I guess this doesn't help very much.
"Some Talk the Walk while others Walk the Walk" |
06-08-2010, 06:22 AM | #8 | |
06-08-2010, 06:27 AM | #9 |
Does the new radiator's OVERFLOW TUBE stick up too much. If so, it can be bent out of the way it is just a copper tube.
I did that on a new Bratton's HD radiator 1930-1931 to fit a thermo quail. |
