06-02-2010, 05:25 PM | #1 |
model B 4 cyclinder carb adjustment
Hello experts. I have just rebuilt my stock 32 4 cyclinder carb. The end result is a mixture significantly too rich. What should I try? Thanks.
06-02-2010, 09:48 PM | #2 |
Re: model B 4 cyclinder carb adjustment
Also, can you notice the changes resulting from small adjustments of the GAV? If not, then the valve seat drilling in the lower casting may be worn wider than the maximum 0.125 inches. In this event, your carb will always run more or less on the rich side because it allows too much fuel into the main jet - cap jet network. Unlike the Model-A carb, the B-carb was designed for the GAV to be completely closed after warm-up. |
